Old 07-15-2014, 10:30 AM   #15
Dustycowgirl's Avatar
1968 26' Overlander
Ocean isle beach , North Carolina
All of it as of now. I was planning on tearing it out though I don't want to keep it Click image for larger version
Name:	ImageUploadedByAirstream Forums1405441794.513547.jpg
ID:	216405 we do want to replace the floor just wanted to do a shell on replacement of it. Not even sure shell on is possible with the new info and pics you sent
Dustycowgirl is offline   Reply With Quote
Old 07-15-2014, 11:25 AM   #16
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
The bathroom will need to come out if you want to replace the floor under it. Even if you don't want it, I'd advise you to take it out carefully and see if you can rehome it to someone else restoring an AS. Those parts are very hard to find.
If you take it all apart so your trailer is bare inside there's no particular reason you have to lift the shell, you can still do the floor replacement with the shell attached though there is not much holding it together at that point. It will still save you the trouble of bracing and lifting the shell though.
Stephanie
Old 07-16-2014, 08:51 AM   #17
1968 26' Overlander
Has anyone cut the belly pan straight across at the axels to make it easier to get out
Old 07-16-2014, 08:51 AM   #18
1968 26' Overlander
Also started working on taking apart the bathroom I am being very careful and will save all parts till the project is totally finished
Old 07-16-2014, 09:42 AM   #19
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Hopefully you can get some more advice from those who have done a whole floor replacement. I have only done a partial, so I did not have to worry about things like the shell being loose or getting out of shape, since only part of it was unattached.
Stephanie
Old 07-16-2014, 10:02 AM   #20
DFlores's Avatar
1968 22' Safari
Yes, you will find that when you go buy replacement material that it is sold in sheets that are not as wide as the trailer, so you will end up installing 4 sheets with seams across half way and down the center.
ID:	216460   Click image for larger version
DFlores
David & Diana
DFlores is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Trying to deal with belly pan replacement perryg114 Belly Pans & Banana Wraps 10 09-23-2011 06:45 PM
Belly pan completely off......???? gutsgolf Belly Pans & Banana Wraps 33 10-28-2009 02:25 AM
Belly pan off or on ? augier Belly Pans & Banana Wraps 6 08-08-2009 02:04 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
