09-17-2011, 07:39 AM
1981 31' Excella II
New Market
, Alabama
Trying to deal with belly pan replacement
I have 31 foot 1981 Excella II. I am in the middle of replacing the floor in the rear bedroom. I think everything is going to go back together well. In order to get to bolts for the floor and get access to C-channel area I have had to remove the belly band. The worse area to remove was at the back of the wheel well where there are about 6 rivets holding almost as many pieces of metal together. I don't know if that is going to go back like it should. I think I am going to make a seam right at the BAL jacks because going any further is going to be a real pain with all that is going on with plumbing. The sheet metal is in relatively good shape about there anyway.
The BAL jacks are going to be fun to remove and I am about 90% sure the bolts are frozen. I guess I will drill and tap new holes slighly offset from the ones that are in there. I can get by without them for the short run.
Where do you find sheet alumimnum that is wider than 4 foot widths?
Perry
09-17-2011, 08:16 AM
1981 31' Excella II
New Market
, Alabama
Here are some pictures of the area where I want to make a seam.
09-22-2011, 09:16 AM
1981 31' Excella II
New Market
, Alabama
I think in the short run I am going to leave off the banana wraps and belly skins till I can take the time to put things back together correctly and not hurry and have to do it over again. The insulation is gone and the frame has been painted with POR15. The new floor section will be covered in polyurathane. I will probably put some aluminum tape along the belly seam to keep water out. I will seal some of that area with Vulkem to keep water out. Since it is all open at this point, water will not hurt anything even if a small amount gets in there. There is only about 6ft between the rear tank and the bumper anyway. I want to put her back together properly and not rush this. I need to get the inside liveable before we go on vacation. If I have time I will work on the skins.
Perry
09-22-2011, 09:21 AM
Rivet Master In Training
1965 22' Safari
Mount Airy
, Georgia
As crude and sacreligious as it may be This was my answer to a belly pan fix....Pretty easy to remove now if I have to get to something underneath.
09-22-2011, 09:35 AM
1981 31' Excella II
New Market
, Alabama
How long you think the particle board will last or is it temporary?
Perry
09-23-2011, 05:13 AM
1965 22' Safari
Mount Airy
, Georgia
Perry, Its not particle board, it's OSB, and there is a huge difference. It also has been treated with three coats of TWP. The honest is answer is that I do not know, considering how infrequently it will get wet. I can say that I have used this combination in other applications ( out buildings decks, etc ) that have stayed in the elements and gotten 10 years before it needed another coat of sealant. I have every hope that this will do as well or better, and if i have to wait ten years to seal it again, I will be ok with that :-)
09-23-2011, 09:26 AM
Tool Hoarder
West
Replaceing the belly pan is not as big a deal as everyone makes it out to be. It beats the crap out of frame repair!!
09-23-2011, 12:20 PM
1981 31' Excella II
New Market
, Alabama
Everything is a pain the first time you do it.
Perry
09-23-2011, 02:39 PM
1965 22' Safari
Mount Airy
, Georgia
Perry
Amen to that....I have actually pondered finding another one to restore. So I could do all the things I wish i had dome to the first one and in half the time :-)
09-23-2011, 06:45 PM
1981 31' Excella II
New Market
, Alabama
It is probably a good time to buy trailers with the economy the way it is. I am not so sure it is a good time to sell them. I have definitely learned a lot about Airstreams in the last few weeks. Did learn one thing and that was stay away from the rear bathrooms if you can and I did.
Perry
