Old 09-04-2011, 11:59 PM   #1
Tool Hoarder
West , California
The '65 gets a new belly
Just thought I would post the belly pan phase of the restoration of my 1965 Sovereign I used 5052 H3 aluminum .032. I am about half way done i will keep posting my progress until I am finished with this phase.
Here are some pics, enjoy!
ID:	139415   Click image for larger version
marzboy is offline   Reply With Quote
Old 09-14-2011, 09:05 AM   #2
Tool Hoarder
West , California
3/4 done
Here are a couple more pics of the belly pan and trailer wireing. I have been going back and forth between the belly and hunting down parts for my axles. Included in the pics are a couple shots of my spare tire carrier that I installed under the front of my trailer just behind the tongue. Enjoy!
ID:	140191   Click image for larger version
ID:	140193   Click image for larger version
Old 01-03-2012, 08:39 PM   #3
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Just came across your posts on belly replacement,looks really good.Like new!
desertair27 is offline   Reply With Quote
Old 01-03-2012, 08:45 PM   #4
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
Looking great! Putting a new belly pan on is the one step that makes me shutter. I hate that pan! But it sure does look good!
Eric H is offline   Reply With Quote
Old 01-03-2012, 09:51 PM   #5
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I'm digging the spare tire mount also,that's another thing I need to put on my to do list.
Old 01-03-2012, 10:33 PM   #6
Tool Hoarder
West , California
Thanks guys, the belly pan is actually finished but I got a little distracted with the axles, dropping the shell back on, replaceing the lower rear pannels and buck riveting. There are a few more rivets and the street side banana wraps to call it complete. Hope to finish up this weekend and post pics. The belly pan is not hard at all to replace it just takes time. There is also a lot of tiny jobs to do before you can do the big jobs. The spare tire carrier is pretty cool if anyone wants more detailed pics let me know.
Old 01-03-2012, 10:58 PM   #7
Eric H's Avatar
1974 23' Safari
Don't want to get too far off topic, but what buck rivets do you use and where did you get them and your rivet gun? Also wondering sizes on the buck rivets. Cheers!
Old 01-04-2012, 10:04 AM   #8
Tool Hoarder
West , California
I used these type of solid rivets from Vintage Trailer Supply they are mainly used for the exterior sheet metal. I used these type of rivets for the belly. I got my gun from the same place.
Old 01-18-2012, 06:04 PM   #9
mapleton , Utah
spare tire carrier
also digging the spare tire carrier. is that an as item or your own design?
rumrunner is offline   Reply With Quote
Old 01-19-2012, 12:15 AM   #10
Tool Hoarder
West , California
I got the spare tire carrier from Inland RV. It was a bit of a pain to install but I had the frame taken apart which made it a bit easier.
Old 01-19-2012, 05:44 PM   #11
mapleton , Utah
good to know. I'll check with Andy
Old 01-19-2012, 06:45 PM   #12
Tool Hoarder
West , California
If you need more pics let me know.
How do I remove the belly pan? aluminitus Belly Pans & Banana Wraps 19 10-21-2014 10:50 AM
Belly band sealing perryg114 Belly Pans & Banana Wraps 11 10-11-2011 06:13 PM
What Holds My Belly Band In Place? Alumaholic Clearcoat, Exterior Paint & Trim 2 09-28-2011 03:27 PM
which aluminum sheet for belly pan???? clipperguy Belly Pans & Banana Wraps 2 04-26-2011 05:21 PM
Sewage in Belly - EW! godaddy64 Waste Systems, Tanks & Totes 16 04-19-2011 11:11 PM
