Old 11-09-2009, 09:20 PM   #1
beckybillrae's Avatar
1964 17' Bambi II
Schererville , Indiana
Terrified of the bellypan!
Okay, I posted this & it completely disappeared, so I'll try again. I have left the best for last on my AS project list. The Bellypan!! I have an '86 and I'm sure I have at least one outrigger that's bad. Do I have to take off the banana wrap? I've read a ton of posts & some say they didn't have to take off the banana wrap. Am I better off waiting until Spring to do this job? Will it take forever? I plan of painting w/Por 15 if I ever get the bellypan off. And putting new insulation in (not the pink stuff). Maybe the frame/bellypan ferry took my post off because she's coming to fix me up, but if not, pleeeaase give me some encouragement/advise! I bought my 2 x 12's tonight so I'm set to put the AS off the ground!
Becky
beckybillrae is offline   Reply With Quote
Old 11-09-2009, 10:44 PM   #2
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
Protect your self.
Hi, who knows what critters or what-have-you was in there so protect yourself while removing the belly pan. On our last trip we picked up our first hitch hiker in what I consider a relatively new trailer, that has never been damaged. I guess that doesn't mean much. I have to mouse proof my trailer because the factory didn't.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 11-10-2009, 04:36 AM   #3
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
You don't need to take them off completely, the top seam under the belt molding can remain.
When u drop the belly pan the banana skins will just hang in place like a curtain.
'77 Sovereign Intl 31' CB
Time's a-changing
Old 11-10-2009, 05:38 AM   #4
Kevin245's Avatar
1976 31' Sovereign
Upstate , South Carolina
Hey Becky,
The bellyskin isn't hard to remove. The toughest part is that you will be working overhead, and as such anything in the bellyskin will fall when the aluminum is removed. Wear some form of mask and or respiratory protection (medical condition dependant of course) and tyvek coveralls. I usually wear some nitrile gloves and a faceshield when doing work of this nature as well. I tape the sleeves around my gloves, and tuck a diaper around my collar to keep all the undesireable goodies at bay. The bellyskin can be the primary playground of all things disgusting. It was the primary point of entry for my latest round of mouse entry.
Regards,
Kevin
"...the most confident critics are generally those who know the least about the matter criticised."
Ulysses S. Grant
Old 11-10-2009, 05:38 AM   #5
dbj216's Avatar
1986 34' Limited
Delano , Minnesota
Bellypan Removal
Hello Becky,
When you say outrigger, do you mean the BAL stabilizer jacks? If so, they are mounted to the frame cross member with three rusty bolts. They are on top, or outside of the bellypan. And they are subject to "road rash", especially the rear ones. Spray the bolts with penetrating oil, rap the bolt heads a couple of times to vibrate them loose and spray again the next day. Then try to loosen them and don't cuss too loud when they break. After they break off, get your drill bits out and have at it. Then re-tap the threads. Replace the bolts with plated ones that won't rust so badly.
I removed the rear section of my bellypan in order to clean and paint the frame, replace the stinky pink batting insulation, and replaced a badly corroded belly pan. My wife is convenienced there are scores of mice living beneath our trailer floor. And we do have "mice smell" in the trailer, so we are trying to get that solved. The whole project is just work. Maybe 30 to 40 hours for me working alone. I did not remove the bannna wraps. I did remove the clamps holding the propane line to the water heater, (more rusty bolts!). I did not drop the black water tank cover. I was uncertain exactly how one guy was going to handle that.
It was a little dicy to get the trailer up high enough to work underneath it. I used solid cement block and my heavy duty jack stands on the axles. I jacked it up with my hydraulic bottle jacks very slowly, like 4" a side at a time. I tried to keep the trailer level as I went. I jacked it up about 2 feet, which gave me room to work. Use caution here, as the trailer is very heavy and it can not come off the jack stands. I was working on a gravel driveway adding more difficulty. Other Airstreamers may have better methods.
I drilled out the rivets holding the bellypan in place. Many of them were corroded. Off came the aluminum belly pan. The fiberglass batting insulation was wet in places. And the frame members were rusty.
So wire brush the frame members, prime and paint them. POR 15 is probably best. I used foam insulation as it won't hold water. I sent for some aircraft aluminum, cut and riveted a 60 wide by 75 long sheet, and riveted it in place. I drilled all new holes as it is too time consuming to try to find the old holes. And I drilled a few drain holes in the belly pan so water won't collect there after heavy rains. I may have $400 in just this rear section. Aluminum is expensive, rivets are expensive, insulation is expensive, etc. etc. But my labor is real cheap!
I've got 24 feet of belly pan to do next summer from the axles to the A frame. I'm going to hire someone to drop the water tank covers to clean up that area and check for "while we're in here" items to fix.
Nothing like laying under your Airstream dreaming about all the great places you want to visit!
It appears like your polish job was successful. I want to do that too.
David
Old 11-10-2009, 06:13 AM   #6
1964 17' Bambi II
When I say "outriggers", I mean the piece that's attached to the outer side of the main frame & juts into the banana wrap. I know I have at least one that needs to be replaced because we had part of the floor removed when we fixed the rotted spots. It was pretty much gone due to rust. When I go around & bang on the banana wrap, I can hear junk rattling around in there (either rust pieces or major mouse droppings, but probably both). If I leave the banana wrap on, can one get in there to weld on new outriggers? My son is a welder, so if it's a bit ackward, he'll be able to deal with it. If impossible, I want to make it possible!
Bob, when you say "the top seam under the belt molding can remain", do you mean you have to take the belt molding off? Isn't that what's holding the banana wrap on?
I just bought 2" x 12" boards to raise it up. I only bought enough to raise it up 6". Is that too few? I want to ride it up on there & not jack it up.
Also, if I do start taking things apart now, would it be a problem if I don't get it put back together before the snow starts flying?
And, if I just loosen the propane lines, is there enough play in them to just let them down, or do I have to remove them completely?
I know, I have lots of questions. I hate suprises. I'm stressing about removing the banana wrap because I have recently Vulkemed the entire top of the beltline rail & I'm sure it would be a bugger to get it off. We also Silkafixed the entire bottom of the bellypan when we first got the trailer. It's gonna be a bugger!
Thanks for all your answers so far!
Becky
Old 11-10-2009, 06:57 AM   #7
Birdwell57's Avatar
1978 31' Sovereign
Madison , Mississippi
The belly wrap is riveted behind (under) the side wall, the belt molding is then riveted on top of the seam they create.
Birdwell57 is offline   Reply With Quote
Old 11-10-2009, 07:12 AM   #8
1964 17' Bambi II
It doesn't look like the belly pan and the banana wrap are one piece on my trailer. Is this the same for an '86?
Becky
Old 11-10-2009, 12:55 PM   #9
1964 17' Bambi II
I towed Brutis around to the backyard & put him up on the 2" x 12" boards so he's 6 more inches off the ground. I'm pretty confident I can crawl under the trailer with that much space. I'm going to have my hubby check it out first to see if I have it secure enough before doing much under there. I may even wait until Spring. I took some pictures of the underside while I was out there. It looks like you can take the center of the bellypan off without taking the banana wrap off. I'm not sure about fixing outriggers with them on though. The boxes over the tanks definitely look like a real PITA to remove. I would gladly trade someone polishing time for bellypan/frame time! Here's the pix;
ID:	90616   Click image for larger version
Becky
Old 11-10-2009, 01:20 PM   #10
Melody Ranch's Avatar
1956 22' Flying Cloud
1956 16' Bubble
1947 22' Liner
Valley View , Texas
Images: 57
question
The belly pan looks to be in great shape....as does the rest of your Airstream. What makes you think an outrigger is bad? You are not falling into a trap of "thread hype" on rust/corrosion problems....I hope.
Old 11-10-2009, 04:22 PM   #11
1964 17' Bambi II
My husband spent a lot of time putting aluminum strips across the bellypan to hold it up tightly. We had some of the floor removed due to rot when we first got the trailer. I could see that one of the outriggers was completely rusted through. My husband actually made an "outrigger" made of marine lumber & wedged it in the curve of the banana wrap. This was in an area at the front of the trailer where there is no foot traffic, but I know it's a jerry rigged way of doing things. When I beat on the banana wrap, it rattles with rust or mouse droppings (or both as stated before), so I feel there is more rust that should be dealt with. I really DON'T want to do this. I've spent a ton of time on this trailer & have this last thing to do that will satisfy my mind that it should last another 30 years. I'd like to ignore it & hope it goes away!
Becky
Old 11-10-2009, 05:46 PM   #12
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Call Mike Rowe with "Dirty Jobs" TV show and see if he'll take it off for you! Actually it was a pain for my husband to take off the belly pan. We didn't take off the banana wraps, just unriveted them from underneath the trailer, and they're hanging down. You really should fix that bad outrigger, and check the others, so I'd bite the bullet and do it right. I'm sure you can survive it - wear eye protection (preferably a face shield), respirator, and old clothes that cover as much of your body as possible. You'll feel better when you're done and you KNOW what's under there!
Kay
Old 11-10-2009, 09:46 PM   #13
1964 17' Bambi II
I think when I get after it, I'll leave the banana wrap on & see how it goes. My 1984 service manual (they didn't make one for 1986) says to use snips for the bellypan and to put it back on by overlapping 2" and reriveting. I think I'll remove the rivets, though. I does say if you need to remove the banana wrap you have to remove the beltline...like everyone else said. Does anyone think it would be bad if I started removing it & had to stop due to cold & leave it open for the winter? Would it be alright? I would think it would be....
Becky
Old 11-11-2009, 07:41 AM   #14
1956 16' Bubble
1947 22' Liner
Valley View , Texas
Images: 57
Looks like your on the right path
The reason I asked about the "need" to pull the pan....is mine is obviously so much worse. No question here.
Name:	21 Sovereign belly pan.jpg
Bellypan re-attaching chalcedon Belly Pans & Banana Wraps 30 06-21-2009 01:48 PM
Bellypan Woes Uncle Jack Belly Pans & Banana Wraps 2 07-02-2007 03:10 PM
Scrap the bellypan? dmaiden Belly Pans & Banana Wraps 10 11-04-2006 03:29 PM
Bellypan removal. Bobolo Repairing/Replacing Floor &/or Frame 9 04-15-2005 07:38 PM
Water in Bellypan? Waterman Belly Pans & Banana Wraps 6 12-07-2003 09:41 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
