Old 04-13-2009, 02:40 PM   #15
Weekend Warrior
Mr.Sovereign's Avatar
2000 34' Excella
1987 29' Sovereign
Pace , Florida
Images: 32
Originally Posted by Inland RV Center, In View Post
I should have said, you only seal the underbelly metal that you removed and relocated against the bottom of the floor, so that water cannot get to the plywood.
The rest of the underbelly must, as always, breathe.
Thanks for the clarifications!
WWW
________________________
W. Warren Whitfield
Pace, Florida (near Pensacola)
2000 Excella 34'
2003 Suburban 1500 tow vehicle
Mr.Sovereign is offline   Reply With Quote
Old 04-20-2009, 07:01 AM   #16
Weekend Warrior
2000 34' Excella
1987 29' Sovereign
Pace , Florida
Images: 32
Finished product
The last two weekends have served me well!
I finally finished the spare tire carrier project. I decided to go the route of a custom carrier for two reasons (1) the cost of the stock unit and (2) I wanted something a little beefier that carried the tire closer to the underside. The stock unit leaves a little room and I've read other posts where people have "stuffed" stuff above the tire to keep it from moving around.
Anyway, here's what I did:
Frame was constructed from 1" EMT conduit (normal glavanized thinwall conduit). It can be bent with a hand bender and is very strong for the minimal weight that it adds. I used a 5/8" stainless rod for the hinge in the rear. For the latch in the front, I used 2"x 4" rectangular tubing, and subsequently "shaved" the bottom off to create a deep "U" channel. The latches are 5/16" latch pins.
The largest bulk of the work is the prep; getting the skin off, prepping the belly and reinstalled a new floor pan. The rest was pretty easy. Thankfully Airstream provides the predrilled (and captive nuts) connection on the second "C" channel for the rear hinge. All-in-all, this is a pretty robust mount. I had fun with it, and I'm very happy with the results.
Thanks again for all of your help. Here are some pics....
Warren
ID:	78856   Click image for larger version
ID:	78858   Click image for larger version
ID:	78860   Click image for larger version
W. Warren Whitfield
2000 Excella 34'
Old 04-20-2009, 07:14 AM   #17
Very nice!
That's an elegant solution, WWW. I really like how low the profile is, as well. Well done, and thanks for taking the time to document your modifications.
Old 04-22-2009, 02:35 PM   #18
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Spare tire carrier photos
In response for pictures of my application under the tongue I find that I do have pictures. Unfortunately a virus wiped out many of my pictures but I do have back-up pictures....somewhere. I know where it is but I'm on my way out the door. I will get them posted later today.
Neil.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 04-22-2009, 04:37 PM   #19
FreshAir's Avatar
1966 24' Tradewind
My spare tire holder
Better yet I found the post that I made last year with pictures. It's Post # 20 in this link. http://www.airforums.com/forums/f438...r-41271-2.html. Hope this helps.
Neil.
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 04-22-2009, 04:42 PM   #20
FreshAir's Avatar
1966 24' Tradewind
Neil.
Also be sure to look at my post #22 picture of the tire bracket.
Neil......waddya know this is my post #1500!
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
455 cid
Old 04-22-2009, 10:01 PM   #21
Ottawa , ON
Neil,
Thanks for finding that, and a nice piece of work it is!
And congrats on your 1,500th post!
Aage (sounds like doagie)
Old 07-17-2010, 02:14 PM   #22
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Front Spare Tire Mount Sources?
I would like to mount a spare against the trailer front and then have room for my tanks. Can anyone suggest a source for the correct mount? Trailer is a 56 Safari. As you can see in the pic, I may not have enough clearance for both the tanks and the tire.
1956Safari is offline   Reply With Quote
Old 08-14-2011, 11:07 AM   #23
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I couldn't find an appropriate mount for our 63 Safari...a tire cover and bungee's worked for us...but we're more practical than aesthetic.
PFC
"Tahawus"
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 08-22-2012, 08:32 PM   #24
1973 25' Tradewind
Beautiful , Oregon
Spare Tire Carrier Clearance
Hi folks
I know this is an old post but I book marked it and I am ready to make and install a similar spare tire carrier.
I am concerned about the clearance to the ground. It looks like in the pic, and also with my version that there is about 9.5" to 10"
My question. Is this enough clearance? I don't want to get in a jack pot.
Many thanks in advance
Tony
Rogue River, Oregon
Tony S is offline   Reply With Quote
Spare tire carrier help needed Safari Tim Wheels, Hubs & Bearings 13 05-14-2008 09:34 AM
Spare Tire Carrier '69 Globetrotter dbaur Wheels, Hubs & Bearings 3 05-09-2008 09:51 AM
spare tire carrier Argy 78 Wheels, Hubs & Bearings 1 01-29-2008 05:22 PM
Spare Tire Carrier AirHeadRik Tires 21 04-19-2005 11:24 PM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 09:00 AM
