Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Prev Previous Post   Next Post Next
Old 02-06-2009, 01:12 PM   #1
Profile:  1969 21' Globetrotter
Cambridge , Massachusetts
side panel, rubrail, bellypan interface
Along the sides of my 1969 Globe Trotter, is the side panel continuous behind the rubrail or is the sharply curved part below the rub rail a seperate piece? If it is a seperate piece, is it appropriate to call it the banana wrap or does banana wrap refer only to the pieces with double curvature below the rubrail at the corners. On the subject of the rubrail, is there any special technique to removing the blue vinyl strip that it cradles. Should I try to salvage this strip or is it customary to replace it with new? Are these vinyl strips available? Finally, are there any special proceedures in dealing with the rubrail at the wheel wells? It is at the wheel wells that I get the impression that the side panel and the panel below the rubrail are a single piece. If this is the case, how do you get the shell off the frame? Thanks a bunch. Now to get underneith and clear the way for belly pan removal.
JoePfznik is offline   Reply With Quote
Missing lower washroom panel, side bath '76 31' Sovereign TobyJH 1976 Sovereign 2 04-02-2008 12:05 AM
Rubrail Adhesive and Repair Shepstream Clearcoat, Exterior Paint & Trim 3 08-09-2004 12:01 PM
New interface. Over59 Forum How-To's & Support 0 07-25-2004 08:27 PM
'67 Rubrail Needed Creampuff Parts Archive 0 10-26-2003 11:19 PM
Radio/Light Interface??? 74Tradewind Electrical - Systems, Generators, Batteries & Solar 3 06-18-2002 10:43 AM
