Old 01-03-2012, 10:56 AM   #1
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Sanding on the banana
I have spent a bunch of time working the dents and dings out of the banana wrap for our 66 Safari. I am getting close but have a question to ask you all. A lot ( hundreds probably) of the small 'nicks' from smaller stones have left sharp edges. You can feel them across the skin plus there are as many dark specks where the replaced metal was. The question is whether I can sand all these nicks down, and if I do what is it going to do( or not do) when I polish the banana wraps. These are Al-clad correct?
Thanks ,
Barry & Karen in Mich.
goshawks00 is offline   Reply With Quote
Old 01-03-2012, 11:53 AM   #2
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Barry, I too have many sharp pits on the front banana wrap. I have polished the trailer twice now in 3 years. In some spots I did 7 or 8 passes with the compounder and Nuvite 7. It looks pretty good but but many of the pits remain.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 01-03-2012, 01:24 PM   #3
easplund's Avatar
2014 28' Land Yacht
Phoenix , Arizona
So the title isn't a new euphemism?
easplund is offline   Reply With Quote
Old 01-03-2012, 01:38 PM   #4
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
If that's what it takes to spark some useful insight I'm all for it
Old 02-05-2012, 05:07 AM   #5
1969 18' Caravel
Jensen Beach , Florida
banana sanding
The banana wraps on my 69 are definately not alclad. They are solid aluminum that seems to be somewhat softer than the alclad outer surface. You can hammer/dolly, file, sand or buff as needed and the great part is they buff up more easilly than alclad.
I used a file on mine to take out some hammer marks and "flatten" some areas. 220 grit takes out the files marks then 400 wet or dry then compound. It is very forgiving. Good luck.
DontBSilly is offline   Reply With Quote
Belly skin and Banana Wrap Alloy perryg114 Belly Pans & Banana Wraps 16 03-03-2014 05:12 AM
Fiberglass Banana Wrap easyride Belly Pans & Banana Wraps 7 06-13-2012 10:35 AM
Banana wrap rivets Flynavy Belly Pans & Banana Wraps 2 07-15-2011 03:01 PM
Bumper, Belly Pan and Banana Wrap Repair DKAir Exterior Restoration Forum 0 06-15-2011 05:51 PM
How tough to take off the banana wraps? johnhh Belly Pans & Banana Wraps 11 04-27-2011 10:22 AM
