Old 08-11-2013, 02:05 PM   #1
Central , Mississippi
Roll your own, banana wraps
I've been lucky rolling the edges of new bellypans around pvc pipe when I used .025 but .032 had me worried so I built a wrapper. I am very surprised how well it works. It makes a nice smooth roll that fits very well, no kinks!
ID:	192929   Click image for larger version
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-11-2013, 05:43 PM   #2
dirigible25's Avatar
1997 25' Safari
Yakima , Washington
Nice job, and thanks for the pictures. Next thing we'll hear that you bought an English Wheel and are producing end caps for those who have dents and creases in theirs. Let us know if you go into production
Dennis
1997 25' Safari
2012 Chevy Silverado HD 2500
Duramax/Allison
dirigible25 is offline   Reply With Quote
Old 08-11-2013, 06:14 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Just keeping pressure till it holds shape?
Peace and Blessings..
Channing
WBCCI# 30676
Old 08-11-2013, 06:25 PM   #4
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
I must agree show the corner wraps because the ones on the caravel are in need of replacement (corrosion) plus some dings holes and just need to be replaced!
Cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 07-02-2014, 12:46 PM   #5
1989 32' Excella
Nashville , Tennessee
I can't find the installation process of the banana wrap after I cut the pattern from my old piece. I started at the bellypan/frame riveting, then riveted the stringers, then attempted to mold balance of aluminum to the seam which is covered by the rub strip (molding) and got numbers of crinkles. Spent $72 on the material and am very unhappy. There must be a better process than I am aware of. Can you help?
bluegene is offline   Reply With Quote
Old 07-02-2014, 01:20 PM   #6
1981 31' Excella II
New Market , Alabama
You can buy prefab plastic corner wraps that are used on newer trailers. I would think you would need to be really skilled at using and English wheel to make new aluminum corner wraps.
Perry
Old 07-02-2014, 03:13 PM   #7
1966 17' Caravel
Okay now that I have replaced the belly pan on the caravel I have found that it is 1.easier to do if you flip the frame 2. Will never be perfect (to your taste) 3. Never never go as it should and last feel really good when you are done!
Cliff
Yes I said that! Or did I?
Old 02-23-2016, 05:59 PM   #8
vanster's Avatar
1967 17' Caravel
Oakland , California
We have been struggling with corner wraps for our Caravel. We have made 5 for one corner, used 025 then 032, made a buck, still no luck. Close but they look like crap.
I noticed that this is a very old thread so maybe someone has a solution.
vanster is offline   Reply With Quote
Old 05-11-2016, 10:13 AM   #9
vanster's Avatar
1967 17' Caravel
Caravel Belly Pan HELL! HELP HELP
After 5 tries to make corners, I still can't get the corners correct
Is there anyone in California or even Nevada that can make 4 corners?
The rest I can do
Old 05-11-2016, 10:39 AM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
front banana wrap on my Overlander is dented. Other than a roller what is suggested for getting he dent out? Sandbag and body hammer?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
