Old 09-04-2014, 02:42 PM   #1
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
Replacing belly pan strap without welding
Our straps on the frame that the belly pan attaches have parts missing. Is it necessary to weld on new pieces, or would bolting on be OK? We finally got the floor down and we'd really like to not have to get under there and weld.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 09-04-2014, 03:22 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Since all it does is hold up the belly pan, I would think bolting, or even pop-riveting, would be more than strong enough.
Chris
Old 09-04-2014, 03:59 PM   #3
1967 26' Overlander
Bugtussel , Oklahoma
Should be fine. Use Nyloc nuts.
1967 Overlander International 26ft
2006 Porsche Cayenne Turbo S 520hp 530ft-lbs torque 7700lb towing capacity
mikextr is offline   Reply With Quote
Old 09-04-2014, 03:59 PM   #4
1973 25' Tradewind
Augusta , Georgia
agree with minno - there is not much structural to this piece and pop riveting should provide adequate support. another option might be kb-weld. i've had good luck in the past for light duty applications.
good luck
dennis
DGJackson is offline   Reply With Quote
Old 09-04-2014, 10:17 PM   #5
1967 24' Tradewind
Images: 38
Yyyaaaaaayyy!! Thanks!
~ Hurley
ingrid
Old 09-04-2014, 10:19 PM   #6
1967 24' Tradewind
Images: 38
What kind of material can we use? Cheap and easy would be good.
~ Hurley
ingrid
Old 09-04-2014, 10:23 PM   #7
1967 24' Tradewind
Images: 38
Do you mean jb-weld? How tough is that stuff anyway?
~ Hurley
ingrid
Old 09-05-2014, 07:07 AM   #8
Minno's Avatar
1972 31' Sovereign
Go to your local hardware store and buy some steel bar the same thickness and width as the piece you still have intact. Or close to the same size - it doesn't have to be an exact match for what it's supporting. I buy small quantities of steel and aluminum bar at Ace Hardware or Fleet Farm. Perhaps Tractor Supply would carry it as well.
Chris
Old 09-07-2014, 01:59 PM   #9
1967 24' Tradewind
Images: 38
The existing ones were really heavy. This will be an improvement.
~ Hurley
ingrid
Old 09-07-2014, 02:37 PM   #10
"Tinbad ... the Trailer"
Del Gurney's Avatar
1965 26' Overlander
Ferndale , Washington
I'm just at the stage of removing my pan and assessing my frame condition.
I note that when drilling out the rivets on the curved belly wraps that the
aluminum is under a bit of tension.
IMO .... I think steel would be more rigid to support the tension evenly so the
wraps curve smoothly.
Using bolts seems a logical solution to me for you
Good luck.
Del
Del Gurney is offline   Reply With Quote
Old 09-08-2014, 01:35 AM   #11
1967 24' Tradewind
Images: 38
I agree on the steel, that's what we're going to use. The previous straps felt like iron! Maybe they were.
~ Hurley
ingrid
Old 09-08-2014, 06:39 PM   #12
1967 24' Tradewind
Images: 38
How thick would the steel have to be, at minimum? I found a place that sells channel. I hope it's not too expensive.
~ Hurley
ingrid
Old 09-08-2014, 06:41 PM   #13
1967 24' Tradewind
Images: 38
Is stainless OK? I'm kind of a rube at metal. I know there's a corrosion problem between some steel and aluminum.
~ Hurley
ingrid
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Towing without belly pan? Tradewinder 1959 - 1965 Ambassador 16 08-15-2014 01:14 PM
Attach U channel without dropping belly pan? thinktankair Repairing/Replacing Floor &/or Frame 7 03-23-2014 02:55 PM
Replacing under covering - Belly Pan glarue Belly Pans & Banana Wraps 10 02-14-2014 02:49 PM
Replacing belly pan on '61 Avion - Advice needed Smoky Belly Pans & Banana Wraps 13 09-24-2012 11:51 AM
