Old 03-12-2017, 02:16 PM   #1
1973 29' Ambassador
Haughton , Louisiana
Replacement Belly Pan
Can someone please tell me where i can find the sheet aluminum to replace my belly pan on my 29'Ambassador.I keep finding places that only have 4 foot wide sheets,my pan is 61.25" wide.Thx
captlou is offline   Reply With Quote
Old 03-12-2017, 02:43 PM   #2
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
airpartsinc.com Airparts is awesome
truckasaurus is offline   Reply With Quote
Old 04-04-2017, 01:21 PM   #3
1977 Argosy 28
2000 28' Excella
Michigan City , Indiana
Here is a link to a place that I plan on ordering from in the near future. They specifically mention material for belly pans. Hope it helps. http://www.airpartsinc.com/
Buck Rabbit is offline   Reply With Quote
Old 04-10-2017, 11:18 AM   #4
1976 31' Sovereign
Utica , Ohio
I bought 4 by 10 foot sheets to fit center of cross members which were 48 " center to center then cut to fit width of trailer. more joints than original but worked. look on internet for alum supplier in your area or local fabrication shop. hope this helps. i has a 31 foot, built new frame and in process rebuild.
SILVER BEE is offline   Reply With Quote
Old 07-18-2017, 06:20 PM   #5
1976 25' Tradewind
Loveland , Colorado
Hi, Did Airpartsinc have the 61.5" wide material? I called them and they did not. I am looking for the same.
mbbarnhill2 is offline   Reply With Quote
Old 07-18-2017, 08:33 PM   #6
1979 23' Safari
Wayland , New York
They only have 4' wide but can give you rolled to length desired You'll be hard presssed to find wider that you can get your hands on. Best bet is to find 4'x8' or 4'x10' sheets locally and cut them. 4'x10' is more waste, the distance between the frame rails requires a little over 5' across so you're just wasting the rest unless you have another use. You'll want to cut them so they go from cross member to cross member plus a little.
If the supplier has a large sheet metal shear, make a plan and have them shear it for you, if they dont charge a fortune. I've seen extremes in prices for shearing. My local one is pretty reasonable($25+$2 per cut), one I asked in NJ was ricldiculous($3 per linear foot).
Start at the back and work forward so the seams face backwards so they aren't facing forward which would cause a scoop effect for road spray.
Old 07-18-2017, 09:04 PM   #7
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I am in the process of replacing my belly pan. I ordered 4' Wide material from Airparts. She told me how to cut it for a good edge- score a few times with a sharp utility knife, then bend until it breaks. The floor joists are 24" on center so this will be fine using 48" material. I attached 1" aluminum angle to each floor joist to make it easier to install the rivets blindly, well easier in theory. We'll see how well it works.
Dan
Old 07-18-2017, 09:25 PM   #8
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
I want to provide a strong recommendation for AirPartsInc. I ordered the belly pan material and it arrived in a nice box (to be used to help you cut it and then store the balance) in 3 days.
The photo below shows the 1" aluminum angle that I attached to each floor joist to make installation of the rivets easier.Click image for larger version
Old 08-08-2017, 09:33 AM   #9
Re-Pete's Avatar
1992 29' Excella
Virginia Beach , Virginia
The photo below shows the 1" aluminum angle that I attached to each floor joist to make installation of the rivets easier.Attachment 289823
Hi Dan, looks like your doing a fantastic job. It looks like you are insulating the heck out of your subfloor area.
Questions:
Is the pink material 1"'closed cell foam insulation? And is the yellow material batt insulation?
Please explain the process of the 1" aluminum angle strips for attaching the sheet aluminum. Are you riveting them to the joists and then riveting the belly sheets to them? Not sure I get it, I'm obviously missing something.
Also, are you able to do all of this with out removing the axles? I haven't really studied mine but it looks like I'm going to be removing, propane lines, etc. Not sure about the axles.
Once everything is exposed, what do you think my chances are of being able to upgrade my tank monitoring system to the Garnet SeeLevel system ? Maybe, using my existing wiring. Just wondering if you've already looked into this.
Are you beading your sheet aluminum?
Please post additional progress pictures if you can when you get there.
Regards,
Pete
Pete
Virginia Beach, VA
1992 29' Excella Classic
TV 2006 Dodge Ram 2500 Mega Cab Diesel 4x4
Re-Pete is offline   Reply With Quote
Old 10-03-2017, 06:38 AM   #10
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Pete
If you look at post #114 of my thread (Dan's 66 Tradewind Improvements) you will find my method of installing the belly pan by yourself. Other posts also provide details of the belly pan work I completed.
Dan
Old 10-04-2017, 07:11 AM   #11
Re-Pete's Avatar
1992 29' Excella
Pete
Dan
Thanks Dan.
Pete
Virginia Beach, VA
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Belly Pan Replacement Wolfie Belly Pans & Banana Wraps 5 08-05-2011 11:33 AM
Rear belly pan replacement Adam.Pyburn Belly Pans & Banana Wraps 8 10-03-2010 09:52 AM
Belly Pan Replacement Julison 1969-1971 Caravel 2 08-01-2008 06:46 AM
Belly pan corner replacement Dan Clayton Belly Pans & Banana Wraps 12 09-27-2005 09:01 PM
