Old 02-13-2007, 08:03 AM   #1
1973 23' Safari
Maryville , Tennessee
Images: 13
Removing Rear Belly Pan
I have a 1973 SAFARI that I was tinkering with around the bumper storage area and found a rotted crossmember. The belly pan is one big sheet and not in sections. It is screwed in at the rear with large sheet metal screws. These screws are rusted and will not turn as they just strip when you try to loosen. What is the best method for removing the belly pan back to the stabilizer jacks so I can further inspect the rear end of the trailer?
Thanks in Advance....
ID:	32286   Click image for larger version
kneal is offline   Reply With Quote
Old 02-13-2007, 08:17 AM   #2
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
I just replaced my entire belly pan on my 53' Flying Cloud. What I had to do was drill out the rivets. Then replaced with bigger ones. Thats my suggestion
1953 Flying is offline   Reply With Quote
Old 02-13-2007, 08:51 AM   #3
1973 23' Safari
Images: 13
I ended up getting it off as most of the screws just broke off...Thanks!
Old 02-13-2007, 09:00 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Screw extractors
I bought a set of screw extractors from Sears for <$20 which sometimes work as a last resort. After liberally dousing the screw with penetrating oil and letting it sit the screw extractors will work a little more than 50% of the time. Still sometimes the head will break off and sometimes the screw doesn't budge, but you are no worse off than before.
Rear Air bags PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 24 11-12-2007 06:02 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
Leak in the rear JodynJeep Sinks, Showers & Toilets 10 09-08-2006 09:40 AM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-03-2002 11:49 PM
