rivets
garp,
I was told to use a sharp drill bit and drill out the rivets. It is advisable to use the right size drill bit for the rivet that is being removed. The small rivets that hold on the interior skins utilize 1/8" size holes, so a 1/8" drill removes them easily. i am not sure about the size of the exterior rivets, but it should be easy to determine.
I found that once in a while a rivet would spin with the drill, and holding the head with needle nose pliers helped get the rivet out.
Good luck!
Consider a pneumatic rivt tool to re-install everything. hand riveting gets old after about 10 or so rivets.........
Uwe
