Old 05-30-2015, 04:48 PM   #1
1966 22' Safari
Santa Barbara, , California
Removing Belly Pan
I have a 66 Safari that I want to change the tanks on and put in some new plumbing. I have made a cut in front of the axle from wheelwell to wheel well.The old black tank is out and most of the pan is loose, but I can't get it to release from under the axle.This Safari has had a replacement Dura-torque axle installed by the PO. The skin goes under the mounting flange of the new axle and is pinched in there ( I presume ), so I can't slip it out. I don't want to loosen up the axle bolts if I don't have to, because they seem to be very torqued on.Does anyone have a trick to get around this? I have a Power shear, but I can see there are all the loose wires running down along the side that I don't want to damage.Should I just cut around the mounting plate for the axle, leaving a wide flange of aluminum to reattach to?then I would make they notch for the axle mount larger to accommodate this.
The banana wraps are layered over the belly pan, so I can replace the belly pan with a seam running down the middle, if I want to duplicate what is there.
Any tips or threads or replies are appreciated.
JRow is offline   Reply With Quote
Old 05-30-2015, 07:54 PM   #2
1966 22' Safari
Photo of situation that didn't post…operator error no doubt!
I also wondered if I should cut the gas drops for the back half of the trailer and re-flair them later, so I can get the skins off and back on?
ID:	239612   Click image for larger version
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 08:41 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 01:48 PM
Removing Rear Belly Pan kneal Belly Pans & Banana Wraps 3 02-13-2007 10:00 AM
Removing the belly pan Flyboy Belly Pans & Banana Wraps 9 11-15-2005 09:11 PM
removing corroded belly pan screws Cruiser Belly Pans & Banana Wraps 2 09-14-2003 01:17 PM
