Reattaching banana wraps?
I have removed the front corner banana wraps on our 76 31' to work out the dents. My question is when I reattach them, (they overlap on the outside of the side skin) , should I use a small bead of Vulkem between the wrap and skin sheet to stop any water from running down the inside of the wrap? Also whe reattaching the Extrusion that the trim fits in, should that also be reattached with vulkem underneath it or just run a bead on the top edge after it is riveted in place?
Mike B
