Old 09-01-2010, 01:22 PM   #1
1968 30' Sovereign
Durham , NC
Rear belly pan replacement
Hey everyone,
I'm starting to get working in earnest again on my '68 Sovereign now that the worst of the summer heat is over (not to mention I finally made some money!). I've been needing to replace a section of the belly pan under the old black water tank that's basically corroded at the seams. I'm doing a full gut, seal, and restore so no need to remind me to fix the source of the problem before fixing the symptom
Just wondering what type of aluminum to get and a good source. I've previously been led to Airparts inc, which seems like the place to purchase from, so I'm mostly curious what the best grade of aluminum is for the belly pan. Thoughts or links to a previous post I overlooked are greatly appreciated.
I apologize that I can't put up a picture at the moment, but forgive me, I'm on dial up out here on the farm.
Thanks in advance, I know this crowd is good for it!
AP
Adam.Pyburn is offline   Reply With Quote
Old 09-01-2010, 01:48 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
It's a good question. Here we've got some sophisticated truck box/trailer repair companies with shears and breaks who work with mostly big aluminum sheets. I'd thought I'd just order the panel I need from one of them. I might even hire them to put it on for me after I remove the old panel and clean out the pink sludge.
Gary
Old 09-01-2010, 02:27 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
No need to spend the big bucks for 2024-T3 for the belly pan. Use something cheaper with better corrosion resistance like 3003 or 5052 in the .025 to .040 thickness. Let your wallet be your guide here, use whatever you can get the best price on, without paying for shipping.
Old 09-01-2010, 04:14 PM   #4
till's Avatar
Lisle , Illinois
Images: 108
Does the black tank really need a belly pan over it. I thought that the galvanized box and aluminum eat each other? I have seen the under side of some of the newer Airstream's and they seem to lack aluminum on the tanks.....
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 09-02-2010, 12:56 PM   #5
1968 30' Sovereign
Durham , NC
Thanks for the responses everyone, and for the specifics Aerowood. I think I'll probably go with 5052 H32. They say it holds up good in marine environments and is used for fuel tanks.
Oh, and I do need a belly pan there because I'm removing the tank altogether for conventional plumbing and putting insulation between the belly and the subfloor. I know to you traveling types it might seem like sacrilege, but for now I'm just planning on having a nice trailer to live in. I don't have money for axle work or a tow vehicle. Just looking for a cozy space to rest my feet out here on the farm for now. One day though...
Old 09-02-2010, 04:01 PM   #6
till's Avatar
Lisle , Illinois
Images: 108
No problem. Just an observation. Best of luck with you new refuge.
Tedd Ill
AIR#3788 TAC IL-10
Old 09-17-2010, 04:10 PM   #7
1971 31' Sovereign
Plano , Texas
Belly Pan. I am new to the Airstream site so bare with me. I find some of the terms unusual. Anyway, I am also replacing the underside aluminum sheet that runs the full length of my 1971 Sovereign Land Yaght (27 feet). I am trying not to replace the entire sheet (I presume you call it a "belly pan"?) I have cut off about 8 feet of the rear part and believe that is all I need to replace. Does anyone have experience in just replacing a portion of the undercarriage aluminum. Am I off base in believing i can replace just a portion?
lawyerfloyd is offline   Reply With Quote
Old 10-03-2010, 07:31 AM   #8
1968 30' Sovereign
Durham , NC
lawyer,
i am planning on only replacing a portion. mine is something like 5 X 3 just at the rear. i'll probably vulkem (standard airstream exterior polyurethane sealant) and rivet the aluminum overlaps and possibly tap a few screws into the steel frame crossmembers for added peace of mind.
ap
Old 10-03-2010, 09:52 AM   #9
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
The center underside piece of aluminum is the belly pan. The pieces that run along each side and wrap up the outside a bit Iíve seen called side wraps and also called part of the belly pan. Older ASís do not have separate center and side pieces on the belly as I understand it, hence some of the confusion on names. The four corner pieces are called the banana wraps because of their shape.
You can replace just part of the belly pan. Overlap the seam a couple of inches, and if you can have the seam line up with a frame member, thatís best. Overlap so the piece going to the front is below the piece going to the rear. That way road spray wonít work into the seam as easily.
Do not vulkum the seams in the belly! You want the belly pan to be able to drain any water that might get in there. Also, there are large head rivets you can use that will support the belly pan better than the regular sized rivets. Pop rivets are fine Ė no need for Olympic rivets on the belly pan. Hereís 2 links to large headed rivets you can use. I believe Inland RV also sell them.
http://www.vintagetrailersupply.com/Large_Flange_Rivets_p/vts-283.htm
http://odmrv.com/catalog/index.php?main_page=product_info&cPath=79&products _id=1055
Chris
aluminum, belly pan, exterior
Rear End Belly Pan Devoman Belly Pans & Banana Wraps 20 10-10-2010 08:13 PM
Belly Pan Replacement Julison 1969-1971 Caravel 2 08-01-2008 06:46 AM
Rear Belly Pan Removed monocoque Belly Pans & Banana Wraps 17 02-27-2008 03:34 AM
Removing Rear Belly Pan kneal Belly Pans & Banana Wraps 3 02-13-2007 09:00 AM
Belly pan corner replacement Dan Clayton Belly Pans & Banana Wraps 12 09-27-2005 09:01 PM
