Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 02-24-2008, 12:15 AM   #1
monocoque
monocoque's Avatar
Profile:  1975 29' Ambassador
San Antonio , Texas
Rear Belly Pan Removed
Here's today's photos from removing the rear belly pan on my 1975 Ambassador. The stabilizer jack assemblies which were bolted to the frame and second cross-member were removed first. Note the section of rusted frame still bolted to the stabilizer. Also note the deteriorated places on the pan where the pan was in contact with the frame and/or crossmembers.
ID:	54997   Click image for larger version
monocoque is offline   Reply With Quote
Old 02-24-2008, 01:06 AM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
wow...
I am workong on a 1968 Ambassador, and the bellypan and frame came apart like new. Very little to no corrosion, and rust in only one place worth pursuing.
However, I have seen trailers newer than yours with worse corrosion.
Uwe
Old 02-24-2008, 06:01 PM   #3
monocoque
monocoque's Avatar
San Antonio , Texas
Here's a close up of where the second to last rearward crossmember and frame contacts the belly pan. Also check out the rear most crossmember. Completely rusted through. Today I removed the forward banana wraps and inspected the frame. It's not a pretty site up there either. It's beginning to convince me to replace the frame.
ID:	55038   Click image for larger version
Old 02-24-2008, 06:15 PM   #4
uwe
418
uwe's Avatar
Images: 40
Take a close look at the main frame rails. Crossmembers and outriggers are easy to weld in, so long that the main frame is sound, or at least acceptable.
You can use 3inx5in rectangular tubing with 3/16 wall thickness for crossmembers. Nice and strong, perfect for making tank cavities, too.
Uwe
Old 02-25-2008, 11:52 AM   #5
monocoque
monocoque's Avatar
San Antonio , Texas
Uwe,
Would you call this frame acceptable? I would prefer that it be but the reality may be less than my liking! What do you think?
Todd
ID:	55069   Click image for larger version
Old 02-25-2008, 12:13 PM   #6
drag'nwagon
drag'nwagon's Avatar
Profile:  1974 31' Sovereign
1956 26' Cruiser Overlander
Lambertville , Michigan
Originally Posted by monocoque
Uwe,
Todd
Todd,
In a word, NO! That frame is not acceptable. Keep moving forward and see how things are around the axles and toward the front. You have a great floor plan and a good size trailer, that is worth some work, but the pictures that you have posted look like you need to build a new frame. It looks like the salt air in Corpis has done a number on that trailer frame. The metal that is still there is most likely to thin to weld much to.
Dave
Operation "Save Rudy" Strike Team (charter member)
You mess with the Strike Team,... you mess with the whole trailer park!!
drag'nwagon is offline   Reply With Quote
Old 02-25-2008, 12:46 PM   #7
monocoque
monocoque's Avatar
San Antonio , Texas
Dave,
Thanks for your advise.
You might check out the Frame Rot thread where I posted a more photos and more detail about the condition around the axles.
But I'm beginning to reluctantly agree with you.
If I choose not do replace the frame...what do I do with the trailer would you think? Sell for scrap/parts? Send it back to it's former scuba diving life?
Todd
Old 02-25-2008, 03:38 PM   #8
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
You've come this far...
Dave,
Todd
...says she, chiming in from a safe distance in the bleachers....
Go for it and do the "Full Monte". One I remember particularly had the frame built, a black and white checkered vinyl floor put on top of the new plywood, then the new frame was backed gently under the braced body, and it was fastened back together. I think that several people have been able to have welders make the frame for $1200 to $2000 - that and new axles - and structurally you've got a NEW Airstream. Of course I'm ignoring the plumbing and wiring, but many here can advise and help you with those. Come on, even if you put $15K into redoing this vintage unit it will still be a helluva lot cheaper than new (as I DO know from experience!).
Good luck whatever you decide - oh and if the body is in good shape, it's not a "parter" even if the frame is done for. (If you do sell it, advise the buyer to have it flatbedded out unless they are very near. The frame IS done.)
Paula
Today is a gift. That's why they call it "the present"
Old 02-25-2008, 05:07 PM   #9
monocoque
monocoque's Avatar
San Antonio , Texas
Paula
Paula,
Thanks for the cheers from the bleachers!
Ahh and this is the first I've heard about the possible price tag on a new frame.
I'm seriously considering the "Full Monte" but still gathering data. I wonder about how to build a frame to support the shell? So I can drive the frame out.
Next step is to get a welder out to survey and make a bid.
Todd
Old 02-25-2008, 05:22 PM   #10
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Before you go off the deep end, consider using a sister piece(s) where the rot is.
I used 3/16" alum bent into a C channel to slip into the existing frame.
Used SS bolts, looks great and stronger than new without added weight.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 02-25-2008, 06:21 PM   #11
uwe
418
uwe's Avatar
Images: 40
The section of frame that I can see is completely defective, and needs to be replaced.
Best to drag out teh frame and build a new one on top of it.
I thelps if you level and brace the old frame, so it is perfectly straight before welding on the new metal on top of it.
When the new skeleton is finished, just set it aside and mount the axles etc. The old frame can then go to the scrap yard.
It helps if you can turn the frame over for welding, so that you don't have to weld upside down.
Uwe
Old 02-25-2008, 09:59 PM   #12
monocoque
monocoque's Avatar
San Antonio , Texas
Uwe,
Thanks. This gives me some idea of how to measure a new frame. How would you lift the shell?
Todd
Old 02-25-2008, 10:02 PM   #13
monocoque
monocoque's Avatar
San Antonio , Texas
Bob,
What is a "sister piece?" Do you mean bolting something like a "splint" or a sandwich around the damaged area? Any photos of what you did?
Todd
Old 02-25-2008, 10:13 PM   #14
uwe
418
uwe's Avatar
Images: 40
Uwe,
Todd
Yeah, there's that little issue...
Best to brace it internally to keep from twisting excessively, and then either put it on sawhorses, or hang it through windows, whichever works best and is safe for those working on, under, or near it. Youwill need 3-4 poins across the width of the shell to properly support it. It is about 25ft long, after all.
Uwe
1975 31ft. Inter. Rear Bath, Belly Pan Photo bigjohn Belly Pans & Banana Wraps 3 06-08-2007 03:59 PM
Belly Pan Opinion Please PoconoAir Belly Pans & Banana Wraps 14 05-09-2007 09:11 PM
Removing Rear Belly Pan kneal Belly Pans & Banana Wraps 3 02-13-2007 10:00 AM
Belly pan corrosion Alumi-Naught Belly Pans & Banana Wraps 9 04-13-2006 06:50 AM
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 16 07-18-2004 09:16 PM
