Old 02-28-2013, 03:32 PM   #15
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
So I'm biting the bullet and will be replacing my belly pan in the next month. The existing pan is 62" wide by 16' long. Aircraft Spruce only has 48" wide panels, so it looks like I'll need to order 4 panels at 48"x72". I'm guessing I'll need to create a couple of intermediate cross members since the existing frame cross members don't layout at 4' o.c.
Some questions:
1) Do the panels take a "set" when coiled for shipping? I'm assuming that if they do it's fairly minor and can be worked out, but I get in trouble when I assume something.
2) I'm going to need to add some screw or rivet holes (haven't yet decided between the two) along the frame member since I doubt I'll be able to hit all the old rivet holes in the cross members. Does this weaken the frame to any significant degree?
3) I've made the assumption (there I go again) that I'll run the panels perpendicular to the longitudinal axis of the trailer thereby requiring the use of 48" wide panels cut to 62" long as described above - correct?
Dale
DryFly is offline   Reply With Quote
Old 03-01-2013, 07:18 AM   #16
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I used 6061 T6 and it did not take a set when rolled. I made my new pan in many sections, but found that my cross members were 2' on center, which facilitated running a 4' wide panel cross-wise as you are planning yours. If you do a search of my posts regarding bellypan, you should find some pics of my upside down chassis with the be pan in place.
Old 03-01-2013, 07:21 AM   #17
Belegedhel's Avatar
Houston , Texas
I also wouldn't bother trying to hit the old rivet holes, especially if you are on your back underneath the trailer. I used the monster-headed pop rivets from VTS, and they did the trick.
Old 04-30-2017, 02:32 PM   #18
1981 31' Excella II
New Market , Alabama
Ok here are a few more photos of the new hinge support. I should have posted these years ago.
Old 06-13-2017, 06:06 AM   #19
CashioStream
Zcashio's Avatar
1972 31' Sovereign
Heber Springs , Arkansas
That looks great. By chance did you happen to move your dump valve? I've been thinking of possibly doing that, but not sure where I want it.
In all your ways acknowledge Him, and He will make your paths straight. Proverbs 3:6
Stay Steady
Zcashio is offline   Reply With Quote
Old 06-13-2017, 03:36 PM   #20
1981 31' Excella II
I had no desire to move the dump valves. They are shoe horned between the two center mounted tanks. I removed a section of tank pan and rebuilt the valves. I made a post about that process as well. The worse part is having to confidence to deal with something like that and finding parts for the original valves.
Perry
