Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 09-27-2003, 06:24 PM   #1
j54mark
Profile:
"New" banana wraps
I did get something finished today.
The previous owner seems to have been unable to drive between any two objects without hitting one, or the other, or both. He had managed to hit both front banana wraps just where they join the lower aluminum side wraps.
Mark
Old 09-27-2003, 06:25 PM   #2
j54mark
Profile:
And on the other side:
Mark
Old 09-27-2003, 06:26 PM   #3
j54mark
Profile:
And it would be interesting to know what happened here. No sign of fire - or even anything singed inside. About the size and shape of dual exhausts - but how?
Mark
Old 09-27-2003, 06:29 PM   #4
j54mark
Profile:
I was able to find used banana wraps at Colaws RV salvage, so they are used, but so is the rest of the coach. As you can see, it is dark now, but I did get the streetside finished.
The "new" blue insert is from the same source. I found a rather long piece of the molding lying on the ground, so I pulled out the insert.
Mark
Old 09-28-2003, 05:40 PM   #5
j54mark
Profile:
And finally the curbside. I drilled the rivets in the lower wrap all the way back to the wheel wells, and discovered no insulation whatsoever outboard the main frame rail! Was it in the way of some past repair? Was there never any insulation there?
There is an overlay on the aluminum portion just above shaft for the stabilizer. It's about 8" wide, but for some reason does not show up in the photo.
For the first time since I have owned this coach, it doesn't look like it was dragged out of a creek bottom.
Mark
Old 09-28-2003, 06:07 PM   #6
59toaster
59toaster's Avatar
Profile:  1959 22' Caravanner
Atlanta , Georgia
Images: 22
Mark
Jacknifed the tow rig and left it running when they couldn't get it straighted out.
Looks good!
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 10-27-2003, 02:15 PM   #7
trogers713
Mr. R
trogers713's Avatar
Profile:  1984 34' Excella
Rogersville , Missouri
Cost of Banana Wrap
Mark, could you tell me what the used Banana Wrap cost you? I called Colaws and they told me it would run 5.00 per inch. Did you pay that much.... I need to find several pieces for my 69. Does anyone fabricate it new? Tim
trogers713 is offline   Reply With Quote
Old 10-27-2003, 02:21 PM   #8
j54mark
Profile:
Yours are quite different. Mine are plastic, where you have aluminum. I have been through the Colaw lot pretty thoroughly, and I am certain there is nothing there that would work on your '69. It would be interesting to know what they thought you wanted to buy.
I got the wraps, some trim, and a couple of odds and ends (litterally picked up off the ground), and paid $50.
Mark
Old 10-27-2003, 08:38 PM   #9
gerbermania
gerbermania's Avatar
Profile:
Wow, those wraps look great, Mark.
Does anyone know when AIRSTREAM switch to plastic banana wraps?
I'm guessing that is also why they started making them a darker grey, it gave them a reason to color-code different materials, which is generally a good thing IMHO.
I have a 1969 with aluminum banana wraps, and they all have some dents. Plastic would be *much* easier to refurbish.
Christopher
gerbermania is offline   Reply With Quote
Old 10-27-2003, 08:59 PM   #10
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 40
Christopher,
Andy from InlandRV says the plastic ones can fit the earlier trailers without a problem. I was eyeballing them at his facility in Corona recently....mine are sorta rough also.
Uwe
Old 10-28-2003, 08:36 AM   #11
apple 1
Profile:  1996 30' Excella
Brighton , Michigan
My 81 Excella had the plastic parts and was also the first year for the grey bottom.
apple 1 is offline   Reply With Quote
Banana Wrap Finish trogers713 Belly Pans & Banana Wraps 6 10-29-2003 02:26 PM
Banana Wrap trogers713 Belly Pans & Banana Wraps 1 10-27-2003 05:36 PM
Honda parallel banana plug source gklott Generators & Solar Power 2 08-09-2003 03:42 PM
"New" 1969 Safari question... Bob Boucneau Our Community 5 07-08-2003 01:49 PM
Washing/waxing "new" clearcoat Kistler 2003 International 13 11-21-2002 09:27 AM
