Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Prev Previous Post   Next Post Next
Old 09-09-2009, 06:45 PM   #1
Emerson77's Avatar
Profile:  1975 25' Tradewind
Hanover , Pennsylvania
Mesh screen for a section of the belly pan...normal?
I just recently purchased a '75 Trade Wind. The other day I was under it trying to determine if my axles are bad, and while under there I noticed a section of the belly pan was a metal mesh screen riveted to the solid panels around it. Is this normal? It is directly under the refrigerator just to the left of the door (looking at the door from the outside) and to the right of the axles. I can see the bottom of the plywood sub floor which doesn't seem right to me that the untreated plywood would be so clearly exposed to outside elements. The mesh section is maybe 1' x 2' but I'm just guessing by what I can remember seeing. The good news is that the plywood floor appears to be in good shape from what I can see!
Eric
Emerson77 is online now   Reply With Quote
Belly pan off or on ? augier Belly Pans & Banana Wraps 6 08-08-2009 03:04 PM
belly pan hlink Belly Pans & Banana Wraps 10 09-16-2008 08:51 AM
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 16 07-18-2004 09:16 PM
Belly Pan Removal... aviontt Belly Pans & Banana Wraps 2 07-02-2004 05:47 PM
Belly Pan Aluminium Streamsaver Belly Pans & Banana Wraps 3 01-17-2004 11:59 PM
