Old 01-01-2015, 02:49 PM   #15
GlamperGirl
Boeing used to have an amazing surplus warehouse you could drive to. Closed several years ago. All online now I think eBay. Very silly.
I have a local source called Alaska Copper here in Seattle I can compare pricing to.
Thank you
thumbelinadj is offline   Reply With Quote
Old 01-01-2015, 09:06 PM   #16
vanster's Avatar
1967 17' Caravel
Oakland , California
I just purchased a sheet of 0.25 5054 from Coast Aluminum in San Leandro CA
4 x 10ft. The cost was $96. They sell 4 x8 and 4 x 12 as well. I have the original pan that we removed very carefully, so we do have some sort of a template. However I built a spare tire rack under the front and now we have two water tanks on either side of the axle.
I don't seen a need to cover the tanks since we built a galvanized skid plate for both. I don't have a brake, and I am wondering if anyone has built a brake.
Name:	Belly pan A.JPG
ID:	229662   Click image for larger version
Name:	bottom of tank.jpg
vanster is offline   Reply With Quote
Old 01-08-2015, 04:58 PM   #17
GlamperGirl
Sourced 5052 .032 today for the Belly Pan $60 a 4x10 sheet. Media Blasting the frame instead of hand grinding it myself. Thanks all
Old 01-08-2015, 11:12 PM   #18
vanster's Avatar
1967 17' Caravel
This seems to be a good deal for a sheet of aluminum. Must have been a local Seattle supplier.
Old 01-09-2015, 05:14 PM   #19
GlamperGirl
Yes. Alaska Copper and Brass
Old 01-09-2015, 05:21 PM   #20
Central , Mississippi
Prices must vary all over the place. I've been buying it in Mississippi for several years now, 3003 .032 4 X 10 sheets run me about $42 a sheet. The again, I've bought so much that they know me and I might be getting a discount
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-09-2015, 11:21 PM   #21
vanster's Avatar
1967 17' Caravel
Is 3003 cheaper than 5054 or more expensive?
Old 01-09-2015, 11:49 PM   #22
crisen's Avatar
2012 25' FB Eddie Bauer
Fairbanks , Alaska
Generally 3003 is very slightly cheaper but you should really pick the alloy based on what it to be used for. When the time to fabricate is considered, differences in material cost are minor.
Rick
"When you find yourself in a hole - quit digging!"
2012 1/2 Eddie Bauer, 2016 Ram Laramie 3500 SWB 4x4 6.7L Cummins 68RFE
crisen is offline   Reply With Quote
Old 01-10-2015, 02:22 AM   #23
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Having done many Belly pans on both early 60's and mid 60's trailers with clean, tight, correct installations, I have learned a few things. First the type of aluminum is first and foremost key to success. 3003, 5052 are too soft types of aluminum and are very, very easy to crease in the critical corner areas of the belly pan. SO, you must use 2024 that is very hard to crease, but also hard to work with, but in the long run the most forgiving... The second thing I have learned is working upside down is hell! So if you can, assuming you are doing a full body off install, and can flip over the chassis to work on it, (like it was done in the factory) life will not be so simple. The third thing I have learned is using the old belly pan as a pattern will get you 90% (yours is gone so who cares) too the original belly pan but 90% is not close enough. As these trailers age and function they work themselves out of shape, hence one of the reason(s) the belly pan failed. Forth the .020 or .025 aluminum thickness that was used is not fun to work with and again is one of the reason(s) the belly pan failed and who wants to replace a belly pan twice on the same trailer knowing how hard it is to do, so I have found .040 works the best. Lastly the corner transition, and area of frame intersections are the hardest part and why the old belly pan is only 90% correct. SO to answer your question yes it can be done, the challenge is do you have the right tools, know how, and extra Aluminum because your first time around will become the templet for the second and depending on how picky you are may become the templet for the third... but like they say third times a charm!
ID:	230170   Click image for larger version
ID:	230172   Click image for larger version
Name:	step detail.jpg
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 01-10-2015, 03:09 AM   #24
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Vinstream, could you provode some explanation of what the second photo above shows us? Thanks, Hank
See my 1956 Flying Cloud renovation thread.
RankAm is offline   Reply With Quote
Old 01-10-2015, 02:31 PM   #25
vinstream's Avatar
RankAm or Hank,
The second photo you are referring to relates to the reshaping of the corner area of the belly pan. Below I have posted additional pictures detailing the steps to help better understand how to create a nice tight fitting corner without causing gaps between the channel and the outer skin or in many cases the skin rip that you see on many trailers even from the factory at the time.
So the first photo you will see lines scribed on the part. These are reference lines from the curve of the trailer that you are replacing the belly pan, not from some other trailer. There are two parallel lines... One at a lose fit the other tight fit. The lose fit is the scribe line you made from your trailer the other, tight fit is about a 1/4' in and this is where your bend will happen.
Next in the picture you will see several holes drilled to 1/2" in size. The placement is critical, the outside radius is about 1/4" from the bend line. The holes do two things they prevent the aluminum from cracking past this point and for an area for the aluminum to go. When you bend aluminum it wants to go some place and with out the holes the aluminum wants to crease.
The next picture you will see "v" cut out of the aluminum toward the whole you cut. This will create the tab part that will be sam-witched between the "c" channel and the outer skin. This is one of the keys to make a tight fitting belly pan with out creasing or splitting of the aluminum.
The third picture the one you were referring too it using a planishing hammer to create a nice tight 90 degree bend in the aluminum. This creates a 1/4" lip that will be covered up by the outer skin, and make the fit up a snap. If you did not do this step it would have to be done by hand with a hammer on the trailer fit up as you went like they did in the factory, but also leaves many dings and scrapes from the tooling. I place PVC on the aluminum before I do this to protect the part.
The forth picture shows the finished part, pre-formed and ready to be riveted and sealed into place.
The finished product when installed correctly shows no creases, no rips in the aluminum that the rub rail in many cases covers up, but does not properly seal from water.
Hope that helps..
ID:	230201   Click image for larger version
ID:	230203   Click image for larger version
www.VINSTREAM.com
WBCCI # 1962
Old 01-13-2015, 11:38 PM   #26
RankAm's Avatar
Dallas , Texas
Vinstream, thanks for your informative post. Very impressive techniques!
I do not have access to a planishing hammer, but the other techniques will be helpful when I put the belly pan on my 1956 Flying Cloud.
Do you do any V cuts along straight edges (where the belly pan joins the straight curb side or the street side)?
Also, would you please explain how you scribe the two lines (the "loose fit" and the "tight fit")?
Thanks again for all the very informative posts!
Hank
Old 01-29-2015, 07:51 AM   #27
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
I have found a very inexpensive source of belly pan material in 4ft x 8 ft sheets. $32 per sheet with no minimum order and if rolled, UPS Ground shipping is very reasonable.
5052 Aluminum Sheet - Aluminum Sheet
You need to call to get sheets larger than 48" x 48".
BambiTex is offline   Reply With Quote
Old 01-29-2015, 08:29 AM   #28
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Thanks Guys. A ton of great info here. My rear bellypan was grounded and needs replacement too. What works best to hold it up while drill/riveting? A sheet of plywood on jack stands perhaps?
NavyCorpsman is offline   Reply With Quote
Difficulty removing tire and wheel assembly litlgeezer Wheels, Hubs & Bearings 15 09-19-2012 08:17 PM
Time to fabricate a new 'Control Center' dalefox Classic Motorhomes 8 03-24-2011 12:39 AM
Difficulty opening windows RV H-D Lady Windows & Screens 13 12-08-2010 05:43 AM
Difficulty posting afinpdx Forum Admin, News and Member Account Info 4 08-18-2005 05:16 PM
having difficulty renting an Airstream lloyd cicetti Our Community 6 03-25-2004 03:00 PM
