Old 08-15-2015, 03:14 PM   #1
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Installing belly wrap
I have noticed on different threads that different techniques are being used to install the belly pan and belly wraps. What is the general consensus on installing the wraps and pan. I have noticed some are putting the belly pan on then putting the belly wrap over the pan and some putting the wrap on first then the pan. Which would help prevent water build up, my 72 had the belly pan over the wrap. Figured I would do it right since my shell has not been riveted to the C channel yet and took Aerowoods recommendation on putting the banana wraps and belly wraps behind the sheeting.
cole3444 is offline   Reply With Quote
Old 08-15-2015, 04:12 PM   #2
1981 31' Excella II
New Market , Alabama
I prefer to put the belly skin on last so I can get in there to inspect for water and corrosion damage. I am also not a fan of rivets because they are a royal pain to remove. I used 1/4-20 stainless screws on the belly skin and .032 aluminum. All I needed were screws tapped into the frame members. I did not need any on the crossmembers.
Perry
Old 08-15-2015, 06:38 PM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I riveted the side wraps under the side skin and have no regrets with that decision. The belly pan itself is installed using 10/32 hardware into aircraft floating nut plates. I used all existing rivet holes and installed nut plates in each
Old 08-16-2015, 03:57 PM   #4
1971 31' Sovereign
1972 31' Sovereign
Belly Pan
Thanks perryg114 and Aerowood, I was hoping that I was going to do it right and both of you reassured me of that. Thanks Jim
Old 08-16-2015, 06:18 PM   #5
1981 31' Excella II
The floor in my trailer is installed with 1/4-20 tapped elevator bolts since the frame is a box not a channel there is no way to get a nut on the back side. I installed the belly pan the same way. You need a tap drill for 1/4-20 and a plug tap. Drill a hole, then tap with the tap in the drill then install screw. Aerowind's method is a little more high class but the end result is the same. I have a center bath so there is only a back and front section to deal with. The center is taken up with pans for 3 holding tanks. If you have a rear bath then you might want a separate panel for between the axles. You going to have to use 4ft sections unless you can find 5ft wide sheet aluminum. Typically you can get 4x10ft sheets. So you can make two 4 ft sections out of one panel. I think the frame rails are around 5 ft wide.
Perry
Old 08-18-2015, 12:07 PM   #6
1971 31' Sovereign
1972 31' Sovereign
Belly Pan
Taking the plunge and driving to Georgia to Air Craft Spruce to pick up my 5052 .032 aluminum to get the belly finished. Shipping is unreal on shipping these sheets, so a little 2 1/2 hour road trip. Thanks for the input I received from perryg114 and Aerowood.
Old 08-18-2015, 12:16 PM   #7
1981 31' Excella II
Most decent size towns like Chattanooga will have a place that sells sheet metal and structural steel. Aircraft Spruce might even have some wider sheets. This stuff comes on a roll and they roll it out cut it and ship it on a pallet. 6061-T6 is pretty common and it works well as a belly skin also. You going to Atlanta? You are not that far from me. I am a couple hours west of you in Huntsville, AL.
Perry
Old 08-18-2015, 07:37 PM   #8
1971 31' Sovereign
1972 31' Sovereign
Belly Pan
Perryg114;
I thought the same thing on somebody in Chattanooga would have it, but called Siskin Steel the supplier for most shops and the lady told me they did not have any 5052 or 6061. They have a scrap pile that the main shop sends over and it might have something I could use. Blew my mind as big as they are. Thought about calling one more time and ask someone else. I will check with Air Spruce on wider sheets since I am picking it up. Won't be far from you, got to run over to Birmingham when I go to Atlanta to look at an awning.
Old 10-22-2015, 12:16 PM   #9
Marufaru's Avatar
1976 Argosy 26
Atlanta , Georgia
Cole3444, did you get your metal in Peachtree City, GA? That's where I live and am thinking of getting it from.
Marufaru is offline   Reply With Quote
Old 10-23-2015, 07:38 AM   #10
1971 31' Sovereign
1972 31' Sovereign
Belly Pan
Marufaru:
Yes I did buy mine at Aircraft Spruce in Peachtree City. They were great, loaded the sheets with no problem. Make sure they are loaded flat. Which I had got a sheet or two extra due to the drive. If you need Clecos to hold the sheets they have a good price on them also. Loved their store. Good luck Jim
Belly skin and Banana Wrap Alloy perryg114 Belly Pans & Banana Wraps 16 03-03-2014 06:12 AM
'63 Ambassador belly wrap esmaytum Belly Pans & Banana Wraps 0 07-30-2011 09:27 PM
Bumper, Belly Pan and Banana Wrap Repair DKAir Exterior Restoration Forum 0 06-15-2011 06:51 PM
Belly Pan & Banana Wrap Removal IronGiant Belly Pans & Banana Wraps 2 06-06-2009 09:56 PM
Floor and Frame fixed, now I need some belly and wrap help heavye Belly Pans & Banana Wraps 3 02-23-2007 01:14 PM
