Old 06-02-2015, 01:32 PM   #1
JitneyBead's Avatar
1964 22' Safari
Tulsa , Oklahoma
How Would You Repair These Wraps?
1964 Safari
We use our AS a lot, traveling with it a few times a year and its an extra living space we use for office, guests, getting away from the effin' kids.
Incurred this damage/rip to the front right banana wrap with a too tight turning radius and an unfamiliar TV. Also including pic of left side to show the dented version I have.
The rip is bad for sure and needs to be repaired somehow. Here are what I think are my options, I'm interested in opinions on pros and cons and what you might do based on your experiences.
A) Band Aid patch
This isn't a trailer queen. I care what it looks like up to a point. I could remove the blue band strip only and fashion a 6-8 inch patch, shaped by hand to match the curve - I have access to a machine shop with a wheel. Pop rivet the patch to the original and seal seams and be done with it.
B) Band Aid patchplus
Remove the banana panel to access it better, hammer it out from the back, but basically still apply a patch to the area.
C) Replicate
Remove the panel. Get a new sheet of aluminum and use the old to create a new panel. This option is clearly the most labor intensive. It will make me cry if I bang this panel up.
D) Replace somehow.
Look for someone else that builds these panels?
What would you do?
ID:	239843   Click image for larger version
JitneyBead is offline   Reply With Quote
Old 06-02-2015, 01:59 PM   #2
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I bet you can find a used one to replace the torn one and you should be able pop the dent out on the other.
desertair27 is offline   Reply With Quote
Old 06-02-2015, 02:29 PM   #3
helmsman's Avatar
1967 22' Safari
Long Beach , California
Hello JitneyBead:
Looking at your photos, it doesn't appear there is structural damage, only cosmetic. My '67 Safari looks like it's in the same overall condition as yours. Well used and still going strong. Unless your intention is to restore it to better than original (polish it like a mirror), my vote would be for (A) - Band Aid Patch.
When my ST trailer tire blew (new with less than 500 miles on it) traveling at a sustained speed of 55 miles an hour, it ripped up the wheel well and tore a small rent in the side panel. I purchased a small piece of aluminum sheet from Home Depot, shaped it and popped rivited it on. Its been on for several years and no one has noticed it yet.
I'm in my 80's and I would select the easiest and least costly method to preserve and continue using the trailer. Should someone wish to do a complete restoration later, you will have prevented further damage from happening.
Happy trailering!
helmsman is offline   Reply With Quote
Old 02-01-2016, 07:38 PM   #4
1968 26' Overlander
Manheim , Pennsylvania
Hey Jitney... What did you end up doing to fix this? I'm in the sMe exact boat. Trying to figure out a way to recreate the entire panel by hand...
SonOfAnder
'68 Overlander
http://www.airforums.com/forums/f44/...te-145553.html
SonOfAnder is offline   Reply With Quote
Old 02-08-2017, 04:46 AM   #5
Yomster's Avatar
1968 26' Overlander
London (UK) / San Francisco , London / California
Images: 13
Hi there, did you find a way of repairing the gash in the banana wrap? My '68 Overlander suffered the same fate.
Yomster
Yomster is offline   Reply With Quote
Old 02-09-2017, 01:58 PM   #6
JitneyBead's Avatar
1964 22' Safari
Tulsa , Oklahoma
She still has the gash.
I haven't tackled this yet. But my plan, when I do, will be to pop the band off, and just create a patch that is shaped over the gouge. I don't really want to take the whole panel off unless i have to, which would be if I did major restoration. I use mine too much to care about those cosmetics.
Jitney
Old 02-09-2017, 03:21 PM   #7
crestonrv's Avatar
1948 16' Wee Wind
1964 26' Overlander
2007 19' Bambi
crossville , Tennessee
if u decide to make 1 , might as well make both and if you're going to do that make me a few while you are at it !
crestonrv is offline   Reply With Quote
What TV would you buy with these considerations? jami20 Tow Vehicles 81 05-17-2015 04:59 PM
Would You Dare Put These on Your Tow Vehicle? Fly at Night Our Community 8 06-02-2012 02:24 PM
Would you chance it? What would happen? Becky B. Repairing/Replacing Floor &/or Frame 6 03-05-2010 10:06 PM
Would you give me some feedback on these photos ? Dreamland Buyer Guidelines 24 09-30-2007 05:44 PM
