Old 10-25-2011, 11:53 AM   #1
saburkha's Avatar
1976 Argosy 28
Tuscola , Texas
Hole repair at BAL jack mount
Got my old broken BAL jack off and the broken bolt drilled out. Now i'm wondering how I should go about repairing this corroded hole. I don't' want to get into replacing a whole section of bellypan right now, I'd just like to get back to camping. Should i use a new piece of aluminum under where the BAL jack mounts as sort of a patch? and rivet it on with vulkum? or should I just use vulkum to fill the hole and mount my new BAL jack over the hole? Any help would be appreciated.
saburkha is offline   Reply With Quote
Old 10-25-2011, 12:32 PM   #2
1981 31' Excella II
New Market , Alabama
It is not hurting anything to leave it be. I see pink stuff but I don't see a frame that the BAL jack attaches to. At some point, you should pull the skins and get all that wet fiberglass out of there which is most likely the source of your corrosion. You could put some POR15 on it but that panel is not going to last much longer. I would coat the BAL jack with POR15 as well to keep the disimilar metals from corroding.
Perry
Old 10-25-2011, 02:24 PM   #3
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
Aluminum duct tape. Get a roll and carry it with you always. Perfect for this.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 10-25-2011, 03:01 PM   #4
saburkha's Avatar
1976 Argosy 28
Tuscola , Texas
Aluminum duct tape. That sounds like a great idea. I would like to replace these panels at some point, but not during this awesome weather we are having in Texas. Thanks!
1976 Argosy 28
http://argosy28.com
Old 10-25-2011, 03:37 PM   #5
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
be sure to get a good quality Al duct tape. the heavy duty stuff from 3m like the aircraft mechanics use works best. some of the cheaper stuff at Lowes comes off when it gets wet. and yes, Al tape would be a good bet there.
Old 10-25-2011, 04:19 PM   #6
1981 31' Excella II
It seems like to me that a hole at least gives the water a place to drain. I would think plugging it would do more harm than good.
Perry
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Exterior hole repair erinld Ribs, Skins & Rivets 20 11-17-2011 09:08 AM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Vintage Tongue Jack - Reese IndyAnne Jacks, Stabilizers, Lifting and Leveling 11 10-19-2011 01:32 PM
Rivet Hole Repair dmcinfo Ribs, Skins & Rivets 9 06-01-2011 08:04 PM
