Old 01-30-2012, 02:41 PM   #1
2004 16' International CCD
Orem , Utah
Here is area tire blew out & needs repair
My idea is to use epoxy and fiberglass to treat exposed wood maybe inside trailer if I can access and underneath. I will wait till it is really dried out. The wrap part is missing and metal is twisted from tire slapping it. $93 for small 7 inch piece no metal to attach to right now. Any good ideas on fixing this area
ID:	149897   Click image for larger version
ID:	149902   Click image for larger version
starcraft is offline   Reply With Quote
Old 01-30-2012, 05:03 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Most license plates are made of aluminum these days. If you are looking for something to cover the wood. Use 3/4" sheetmetal screws to attach the patch to the wood.
Old 01-30-2012, 05:48 PM   #3
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
Uhhh, am I wrong or is that the outrigger (black bent back piece in front of tire) that is really distorted? Is that a floor bolt bent back? May be more damage than you think.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 01-31-2012, 11:01 AM   #4
1981 31' Excella II
New Market , Alabama
Can you get to the other side of it. You need to get the outrigger bent back in shape and maybe welded back to the frame. Then you need to put some more bolts in it. I would paint the exposed floor with house paint, polyurathane or something to give it some waterproofing. You can get some sheet metal from Lowe's and some silver duct tape to do a temporary job.
Perry
Old 02-10-2012, 10:01 AM   #5
Orem , Utah
Thanks for suggestions
I have bed out and having diamond plate made for storage area. Metal fabrication place can do anything and repairs all types problems. I can get picture of top on plywood. Is there a way to remove those 2 screws? You can see rusty one in front not sure I have access to top, other metalic color I can put philps on to remove. Should these be removed first before trying to bend metal back into shape. Thinking about repairing cracked wood with rot DR something to strengthen it up. Not total cracked in half but bent from bolts pulling. I could use grinder and cut off rusty one and have welder remove metal put new piece on.
Old 02-10-2012, 11:26 AM   #6
1981 31' Excella II
You may have to cut the screws off. One of them maybe between the inner and outer skin in the C-channel. Can you see the heads on the other side? Some closets have false bottoms.
Perry
Old 02-10-2012, 07:40 PM   #7
Orem , Utah
pics from top
You can see wires going in and I found one bolt there and another towards wheel black trash can material. I can get tool on either one looks square and welded to alum? My issue is getting them back in if removed and bending that rigger closer to spec. Plus I need bolt hole for new belly banana wrap. Still unsure if I want to fix this area. How can I bend the metal back?
ID:	150750   Click image for larger version
ID:	150752   Click image for larger version
Old 02-10-2012, 07:50 PM   #8
Orem , Utah
pics from top
You can see wires going in and I found one bolt there and another towards wheel black trash can material. I can get tool on either one looks square and welded to alum? My issue is getting them back in if removed and bending that rigger closer to spec. Plus I need bolt hole for new belly banana wrap. Still unsure if I want to fix this area. How can I bend the metal back? How do dealers fix these areas on trailers. They said they order some material that goes over area like thick carboard or something I was guessing a sticky black rubber piece like used on roofs. If I could get similar black material in plastic would be easier to bend and make it look good but have no clue where to get some. Replacing the floor is not option so I will need to try fix cracked wood any suggestions on nice product?
Airstream Tire Failure Poll Phoenix Tires 150 05-14-2018 07:34 PM
Airstream Repair Kileen/Temple Area! al franklin Our Community 11 11-29-2012 05:24 AM
235/75R15XL vs 225/75-15 trailer tire perryg114 Tires 129 07-18-2012 01:59 PM
Repair service in Phoenix area hoffman General Repair Forum 4 08-03-2011 07:34 PM
Recomendations for repair shop (SF Bay Area) Share All General Repair Forum 1 06-09-2011 10:48 PM
