Old 12-01-2016, 09:21 AM   #1
1960 24' Tradewind
Kingsville , Ontario
Help with...The plan
Hey all, I am about to put the new bellyskin on, and am thinking about using self tapping screws instead of rivets.... any thoughts???? Also, I will be putting a sheet of reflectix insulation between the bellyskin and frame...for added insulation.
KZGoodchild is offline   Reply With Quote
Old 12-01-2016, 09:38 AM   #2
1955 22' Safari
Laredo , Texas
Only with loctite
I tried that and found that they tended to back out. Went back to rivets.
I think self tappers would work if you use some form of threadlock.
55AS is offline   Reply With Quote
Old 12-08-2016, 06:47 PM   #3
amysemmens's Avatar
1960 24' Tradewind
Heyfield , Victoria
Pretty sure they'll cause corrosion?
amysemmens is offline   Reply With Quote
Old 12-08-2016, 07:10 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Fleming Island , Florida
RE: Corrosion - The frame is steel, the screws are steel, only Al is the belly skin. The reflectix will isolate the skin from the frame. Put a plastic washer under the screw head and use some thread-lock.
That said, I have no experience with thread-lock on coarse thread screws like sheet metal screws, but there are lots of self drilling sheet metal screws under my trailer holding on cables, propane lines and such. To my knowledge none have backed out. Thread-lock would be good insurance.
Al
Old 12-08-2016, 11:24 PM   #5
millertimeUS's Avatar
1976 25' Tradewind
Reflectix calls for an air gap fwiw you won't get the R value posted on the box with this setup. Save your money.
Matt
millertimeUS is offline   Reply With Quote
Old 12-09-2016, 11:17 AM   #6
Journeyman
2016 25' International
Amherst , Massachusetts
True...but I want to share this Empirical Data: I sit on cold aluminum bleachers in the winter and I bring a small reflectix pad for my butt. My butt isn't quite calibrated to determine exact R values, but I can tell you for certain that even without airspace there are some pretty clear insulating properties!
Some (hopefully useful) Airstream videos here:
https://www.youtube.com/c/journeymanvideos
thiel is offline   Reply With Quote
Old 12-09-2016, 12:14 PM   #7
LifeIsRiveting's Avatar
1976 25' Caravanner
Kansas City , Kansas
Rivets will be cheaper and lighter. But if you don't want to use rivets then I recommend these "thread forming" Fastite 2000 screws for joining aluminum sheets. If you want to join a sheet to a thick steel frame member then use taptite screws instead. We use them a lot at work and they are superior to typical thread cutting self-tapping screws in many ways. The head profile has a self-locking feature and they drive in nice and straight rather than crooked. A pleasure to work with. See this data sheet for more info...
http://www.taptite.com/pdfs/document...NTI-reminc.pdf
You can get them from McMaster Carr
https://www.mcmaster.com/#fastite-screws/=15ea8yl
Follow our shell-off renovation on Instagram @LifeIsRiveting
LifeIsRiveting is offline   Reply With Quote
Need help with repair plan --- am I insane? _ally General Repair Forum 18 06-15-2016 11:27 AM
Help with phone plan selection for full-timing lg_sylvanlk Full-Timing 23 11-26-2014 07:01 PM
Niagara falls, websites that help plan itinerary pollymenaker On The Road... 10 02-19-2013 05:07 AM
CA to New Brunswick - help us plan guy99 On The Road... 3 09-06-2006 09:28 PM
What's the best roadside help plan? mcneon Insurance & Claims 13 11-13-2003 01:27 PM
