Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 03-04-2008, 11:06 AM   #1
Gkiesel
Profile:  1976 24' Argosy 24
Milford , New Jersey
Front Banana Wrap Replacement
Hello all, my old 76 Argosy is in need of new wrap in the front. the old aluminum is badly dented. Has anyone used the newer plastic corner pieces from the newer trailers? It would seem to me that they would be more durable from all the rocks etc. that assault the front of the trailer going down the road. I don't believe the older style aluminum ones are still available. Any advice would be appreciated. Thanks, George
Gkiesel is offline   Reply With Quote
Old 03-04-2008, 11:32 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
The original metal banana wraps have not been available for some time.
The plastic replacements are holding up very well.
We always have them in stock.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 03-04-2008, 11:50 AM   #3
Gkiesel
Thanks Andy, Are there any issues with the plastic. It seems thicker than the aluminum and taller. What's the best way to trim the plastic if need be? Also, this being an Argosy, the shell is supported in the front by the steel plate. the rivets that held this wrap to the shell were just common pop rivets. Is this correct? Thanks, George
Old 03-04-2008, 12:35 PM   #4
Commercial Vendor
The plastic banana wraps install the same way as the metal.
You trim the plastic with tin snips.
Pop rivets hold them in place.
Paint them whatever color you wish, but first prime them.
Inlandrv.com
800-8777311
Old 07-08-2008, 12:49 PM   #5
Gkiesel
Old posts become new again. Finally ready to paint. Can I paint those plastic bananas with Krylon spray paint or do i need the stuff made specifically for plastic. The rest of the wrapping I painted Kylon leather brown years ago and it has held up well. Thought I would spray the whole lower section again. Thanks, George.
Old 07-08-2008, 06:30 PM   #6
Commercial Vendor
Using Krylon is fine, but put a couple of coats of clear over the color coat.
Inlandrv.com
800-8777311
72 Safari Removing Banana Wrap in front of battery compartment Tom Bray Belly Pans & Banana Wraps 2 08-27-2007 12:55 PM
Body and banana wrap on floor replacement technique. malconium Repairing/Replacing Floor &/or Frame 56 09-09-2005 10:09 PM
Banana Wrap Lumatic Belly Pans & Banana Wraps 2 09-05-2005 07:55 PM
banana wrap: salvageable? pinkflamingoes Belly Pans & Banana Wraps 5 10-19-2004 11:21 PM
Banana Wrap trogers713 Belly Pans & Banana Wraps 1 10-27-2003 06:36 PM
