Old 07-05-2004, 06:11 AM   #1
Send a message via AIM to keylime
Fiberglass Belly? What do you think?
Hey Gang.
Long time since I have posted here, although I am reading so many of the threads lately trying to develop an idea of where and how to proceed with work on the '65 Tradewind. Last month, I was compelled to take her on the road from NYC to Indianaoplis, and the '64 Ford towed her there and back with no problems (w/the tow vehicle.)
It was a good trip, and I was faced with a few issues that, had I not taken the Bean, those issues might not have made themselves evident. The loss of the rear cover-plate (not the thin guage belly-pan) because the black-tank had given way from it's supports has me looking at replacements of both (tank is shot beyond repair.)
Some of the thin-guaged belly-pan will need to be removed because it is corroded, aside from the fact that I noticed some of the steel structure it is covering could use some rust-arresting maintenance. Has anyone ever used fiberglass sheeting (see here for details as a replacement for the belly-skin? I have read where some out there are less concerned with the cosmetics of the belly (out of sight-out of mind?) and it seems as if this could be a decent replacement (available in 5x10') Has anyone ever gone this route?
Best regards to all...
keylime is offline   Reply With Quote
Old 07-05-2004, 07:37 AM   #2
LOST , Hawaii
I would stick with aluminum. Fiberglass is brittle, it would be hard to pull a small section down for an easy repair or inspection. Thin sheets won't hold rivets or screws as well as aluminum. It is heavy. It's going to be nasty to work with if you have to cut it for access to the belly.
74Argosy24MH is offline   Reply With Quote
Old 07-05-2004, 11:51 AM   #3
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
belly pan aluminum is ofter .025, and does ot need to be ALCLAD. It's available in 4x12ft sheets for around $ 50.00, which is probably cheaper than the fiberglass panels.
Old 07-05-2004, 01:16 PM   #4
From the looks of things, I might have to go ahead and remove the entire belly-pan to get to the steel underneath. I feel necessity to arrest whatever rust has been forming over the past 39 years. My concern is in re-using the existing pan-material (I know there are other helpful threads regarding this topic) especially the width is well-over 48". I'll keep digging through the previous posts and come up with a plan of action. Thanks for the comments.
Old 07-07-2004, 08:10 PM   #5
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Why couldn't you use "flashing" its 16" wide and 100' long. If you need more width you could pop rivet them together to get any width panel you need. The stuff is cheap and readily available at Lowes. The Narrower widths should be easier to work with. Am I missing something?
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 07-08-2004, 06:13 AM   #6
Lavek's Avatar
HI All!
Can you tell me where you can get the belly pan aluminum for $50??
Lavek is offline   Reply With Quote
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
where belly meets floor meets shell JrnymnJay Repairing/Replacing Floor &/or Frame 6 01-09-2006 12:05 PM
Water in the belly pan?!?!??? Safari Tim Leaks - Weatherstrips, Gaskets, Caulks & Sealants 22 04-28-2004 01:45 PM
change color of fiberglass??? kent osborn Sinks, Showers & Toilets 3 10-05-2003 03:32 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
