Old 08-13-2016, 05:28 PM   #1
Firemntom's Avatar
Manhattan , Illinois
Fan in Belly pan
Has anybody tried to increase the air movement in the Belly Pan area?
Might try using the "fart Fan" and redirect it to push air into the belly pan area. Place the fan on a switch to turn on when it rains out.
Is this a crazy idea? I would think that it would increase dry time and help prevent moisture build up in the pan.
Let me hear it fellow streamers
1971 Tradewind
Tom
Firemntom is offline   Reply With Quote
Old 08-13-2016, 05:57 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have Feeling you will be the first.
MICHAEL
AWCHIEF is online now   Reply With Quote
Old 08-13-2016, 06:03 PM   #3
Seattle , USA
Don't the modern trailers blow air through the underbelly via the heater? Or, do they only blow air around the gray water tank?
I always assumed that just by running the heater on fan only you could circulate air in the underbelly. Or, run the heater and really dry it out.
Seems like that would make sense...but who knows.
RareStream is offline   Reply With Quote
Old 08-13-2016, 07:06 PM   #4
AWCHIEF's Avatar
Images: 33
Mine does not. It uses 12 volt DC heat strips to warm the tanks. No air flow outside of the main compartment unless I open cabinet doors, etc.
MICHAEL
Old 08-13-2016, 07:25 PM   #5
KYAirstream's Avatar
Northeastern , Kentucky
My 1979 has a duct that blows into the freshwater tank compartment. This area has an opening to to grey tank, but none to the rest of the belly.
KYAirstream is offline   Reply With Quote
Old 08-14-2016, 12:52 PM   #6
airdreamers's Avatar
1985 25' Sovereign
Venice/Nokomis , Florida
Images: 14
Hopefully the dry time with some sort of a fan would decrease the dry time and prevent moisture build up. Have not heard any conversations about those issues so far.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 09:43 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 01:48 PM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 07:58 AM
Belly Pan Gaps? ajjohnsons 2003 Safari 6 07-22-2003 08:16 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 07:03 PM
