Old 11-07-2017, 07:17 PM   #1
Roanoke , Texas
Dropping belly pan
On my '57 Caravanner, I need to drop my belly pan without gutting the interior and taking the interior panels out, so I can see the state of the frame and perhaps wire brush it and paint it from underneath.
Can the belly pan be removed without removing the subfloor and interior panels?
travis90 is offline   Reply With Quote
Old 11-07-2017, 08:11 PM   #2
2007 22' International CCD
Yes, from underneath and it’s NOT fun. Wear protective gear including a respirator rated for Hantavirus, particles, and other stuff. Eye protection, a set of coveralls, and gloves.
Generally the pan comes down by drilling out the rivets that hold it up. Do be careful. Critters make nests in there.
Old 11-07-2017, 08:12 PM   #3
Roanoke , Texas
It looks like the belly pan can’t be removed though from the outside without cutting it off. Am I right? The top edge is in between the outer skin and the subfloor inside the trailer.
Old 11-07-2017, 08:43 PM   #4
1966 22' Safari
Fredericksburg , Texas
In originally assembling, the belly pan was placed and riveted to the C channel. Then the exterior skin was installed overlapping the edge of the belly pan at the C channel and riveted through the edge of the belly pan into the C channel. If it were me and I was just trying to see the condition of the frame, I would cut out a section of belly pan, pull out the insulation and see what it looks like. (Also wearing proper PPE gear like mentioned). You could also neatly cut the belly pan a foot or so inboard and drop the entire center. If you have deteriorated frame members, which wouldn’t surprise me, the entirety may have to come off to access for rework. I know you hate to hear it. Someone may come up with a better idea. Good luck. Bubba
Bubba L is offline   Reply With Quote
Old 11-24-2017, 10:10 AM   #5
islandtrader's Avatar
1956 22' Caravanner
Don Pedro Island , Florida
I don't remember who posted this drawing...I keep it in my files so I remember how the AS is put together. I would go with Bubba's suggestion.
My Rebuild page : 1956 Caravanner
https://www.airforums.com/forums/f11...ml#post1921527
islandtrader is offline   Reply With Quote
Old 11-24-2017, 06:41 PM   #6
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Belly pans were installed to keep the dirt out of the subfloor insulation and maybe hide the frame some. They are not a structural member of the trailer. They are fairly easy to remove. Yep, it's a real dirty job.
My 66 exterior skins wrapped around and mated to the flat belly pan. They did not have to come off. My 86 has separate wraps. I don't know how the 57s were built.
New belly aluminum is readily available. Installing it is a lot of work. But even an old retired guy can do it.
Here is a photo to whet your appetite for a little well aged mouse poop.
David
Name:	1311 Belly Pan Rear (Small).JPG
Belly Pan, No Belly Pan DryFly General Repair Forum 33 10-07-2018 07:41 PM
Attach U channel without dropping belly pan? thinktankair Repairing/Replacing Floor &/or Frame 7 03-23-2014 02:55 PM
Dropping belly pan that covers black and grey tanks? casarodante Waste Systems, Tanks & Totes 20 06-10-2007 01:15 PM
Help Dropping the Belly Frostyone Repairing/Replacing Floor &/or Frame 0 05-14-2006 10:12 AM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
