Old 02-25-2010, 10:09 AM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Drill bit size for Belly Pan
Attempting to remove belly pan today.Rivets look larger than interior.
I am using a rivet removal tool with carbide bits.I have a 30 now,but it only makes a hole through top but does not pop rivet off.
When I use a putty knife to knock loose the rivet it elongates the hole.
bwaysteve is offline   Reply With Quote
Old 02-25-2010, 10:10 AM   #2
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
PS I have the larger head rivets for reinstall from VTS.
Old 02-25-2010, 10:17 AM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Steve, Since you are using the same hole to reattach the belly pan use the size drill bit for the large flange rivets. Here Large Flange Rivets
Looks like the "Ideal drill size is #11 bit" or 3/8 will do...
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 02-25-2010, 11:22 AM   #4
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Thanks Lee!
Old 02-25-2010, 11:48 AM   #5
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I think you mean 3/16"
'77 Sovereign Intl 31' CB
Old 02-25-2010, 11:49 AM   #6
1967 22' Safari
1960 Caravel
Images: 8
I stand corrected. I do mean 3/16".
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 02-25-2010, 12:58 PM   #7
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
I second the 3/16", removed the rest my belly pan yesterday and 3/16" is what I used.
SilverHoot is offline   Reply With Quote
Old 02-25-2010, 01:27 PM   #8
VIKING's Avatar
Boulder Creek , California
If the removal of the pan seems tedious, wait until you have to pop those wide flange rivets when you re-install it. My friend and I had to take turns with the rivet tool because our hands and wrists hurt so much from popping those big bad boys. We wore out a pop riveter on them.
This is a great place to use a pneumatic riveter.
Rich the Viking
VIKING is offline   Reply With Quote
Old 02-25-2010, 01:30 PM   #9
1967 22' Safari
1960 Caravel
Images: 8
Rich the Viking
Could not agree more.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 02-25-2010, 02:21 PM   #10
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Harbor Freight here I come! I figured out the 3/16 once I got to Fastenal.
This is soooo much better.
BTW the1/1/2 in hole saw is working well on the floor.
Twisting bolts off channel but having trouble with the screws and afraid to use sawsall so as not to go through skin.
what size rivet for U channel, skin and belly pan connection? benWa Ribs, Skins & Rivets 5 09-22-2009 08:49 PM
drill size for Olympic rivets walter1 Ribs, Skins & Rivets 2 09-24-2007 10:09 PM
drill size? Stormy Weather Ribs, Skins & Rivets 18 10-17-2004 12:57 PM
What size drill bit for the 1/8 inch in pop rivits? TBKP's Overlander Ribs, Skins & Rivets 3 07-24-2003 11:21 AM
Drill Bit Conversion Chart pap Ribs, Skins & Rivets 2 03-17-2003 09:33 PM
