Old 05-21-2015, 06:22 PM   #1
Westminster , Colorado
Do I HAVE to replace the belly pan?
My belly pan is in pretty good condition. Actually really good. Only the rear panel NEEDS to be replaced. I am taking the shell off to replace the subfloor. My question is: does the entire belly pan need to be removed? Or can I leave on the good parts?
Can someone give some insight? THANKS!
painterfam is offline   Reply With Quote
Old 05-21-2015, 06:32 PM   #2
JimGolden's Avatar
1977 31' Excella 500
Absolutely not! If most of it is good, then by all means reuse it. Just remember, you want to break it at a crossmember, and the piece in the back goes up against the crossmember with the piece at the front overlapping it. That way you don't get crud caking up in the joint if you make it the other way
See ya on the road,
- Jim
JimGolden is offline   Reply With Quote
Old 05-21-2015, 07:11 PM   #3
Thank Jim! So what you are saying is the belly pan needs to come off and be put back on, correct?
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
Keep/repair or replace my belly pan? KCN Belly Pans & Banana Wraps 8 10-26-2012 06:37 AM
Replace Belly Pan Question Dfh54418 Belly Pans & Banana Wraps 4 04-05-2012 01:33 PM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
