Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 01-21-2016, 07:31 PM   #1
GuitarmanFL's Avatar
1972 27' Overlander
1971 31' Sovereign
Orlando , Florida
Corrugated poly sheeting instead of AL
Hey Guys:
My plan is to replace my belly pan with corrugted poly sheeting. It's light, easy to work with, relatively cheap, and impervious to water, and lot easier to install than the AL that I removed - and is in bad shape.
I'm keeping the banana wraps, for sure and banged out the dents so I think they will clean up well.
Problems, thoughts, high-fives??
Brek
GuitarmanFL is offline   Reply With Quote
Old 01-21-2016, 08:03 PM   #2
Kevin245's Avatar
Many SOB's use this and my thoughts are that this would be fine for an Airstream as well.
We have black poly sheeting on our 5er.
William C. Swinney
Old 01-21-2016, 11:05 PM   #3
Andrew T's Avatar
2019 27' Tommy Bahama
London , Ontario
Hi Brek
It does not stand up to heavy gravel like you run into in Alaska but otherwise it has been fine on box trailers. You need about 1.5" flat washers to hold it up.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 01-22-2016, 08:17 AM   #4
1972 27' Overlander
1971 31' Sovereign
Orlando , Florida
Thanks Guys - Anyone know the best supplier?
Old 02-18-2016, 10:45 AM   #5
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
I would run with 1/16 lexan sheet or 1/8 black uhmw sheet. It costs a little more but is way more durable. The lexan would be the lightest and closest to aluminum thickness.
Gearheart is offline   Reply With Quote
Old 05-26-2016, 10:45 AM   #6
1968 26' Overlander
Manheim , Pennsylvania
Hey Guitarman, how did this work out for you? I saw these sheets at Home D the other day. 4x8 sheets that they advertised for sign boards. I thought to myself, that might actually not be a bad idea! Plus, you eliminate the aluminum to steel corrosion aspect that leads to rivets popping loose down the road.
SonOfAnder
'68 Overlander
https://www.airforums.com/forums/f44/...te-145553.html
SonOfAnder is offline   Reply With Quote
Old 05-27-2016, 08:00 AM   #7
1972 27' Overlander
1971 31' Sovereign
Orlando , Florida
Hey SOA:
Good Question.. I haven't gotten there yet. I'm still waiting for my new rolling chassis, and have been biding my time polishing
I did determine the poly sheeting is what other RV makers are using that have a belly pan. So I figure it should hold up fairly well.
Curious: How much were they selling the 4x8 sheets for?
Thx,
Brek
The Shifty Drifter.
2018: 7500 miles: FL to Co
2019: 7500 miles: FL to Co
Old 05-31-2016, 09:13 AM   #8
1968 26' Overlander
I want to say they were only $15 a sheet, but they were only 1/4" thick. I think what most box trailers uses is a bit thicker
SonOfAnder
'68 Overlander
Old 06-03-2016, 05:27 AM   #9
1967 22' Safari
1974 Argosy 26
Pottersville , Missouri
I'd love an update on how the corrugated poly worked for you. I've got a belly skin replacement ahead of me too.
losfew is offline   Reply With Quote
Roof sheeting Rust Roof 2 07-06-2013 09:16 PM
Poly Cord into Case ronsgto Awnings 8 11-21-2010 09:20 PM
Piecemeal replacement of poly tubing & fittings? davida Fresh Water Systems 4 05-28-2007 05:24 PM
POLY - wants a cracker!! Cottage Off Topic Forum 6 02-10-2003 10:37 PM
Question re how to cut aluminum sheeting and get a clean edge... williamhenshall Ribs, Skins & Rivets 7 06-12-2002 05:58 PM
