Old 08-29-2010, 07:43 AM   #1
CanoeStream's Avatar
St. Cloud , Minnesota
Bottoms up!
We clean. We primp. Fix 'em up a little (or a lot) too. Stand back and admire the handiwork. Missing anything? Be sure to look underneath now and then too.
We've heard about the famous jacking (but don't jack on 'em) points. Here's my rear curbside jack point.
Name:	curbside jacking point.jpg
And the rear roadside, same area:
Name:	roadside jacking point.jpg
Yep, I don't have but the single curbside jack point. Useful? BAL jacks are so much easier anyway. BTW -- I have no jack points under the front of my coach either -- don't know if there should have been. meh...
5 meter Langford Nahanni
Old 08-29-2010, 07:44 AM   #2
This first issue has been present since I bought my Safari. The main LP lines are as snug to the belly as they can be. Somehow the plastic side wrap was persuaded to stretch for a couple #8 screws. Never stood a chance!
There's no give or sag to the HW heater & stove feed lines. They're stable as-is IMO.
Old 08-29-2010, 07:55 AM   #3
We put a lot of road miles on our Safari -- enough to experience tired concrete roads with what seems like a ridge at every expansion joint. I've got a few detours I take to avoid some in my region but there's one around the next county. Sure like it when I see they've put an asphalt overlay on these worn out highways.
Bucking between our truck and trailer find that right harmonic and ya gotta slow right down to 45 or so. This is another type of shaken baby syndrome. We've heard about frame flex aft of the wheels. For a couple months I've been observing the consequences at the belly wrap just forward of the bumper box.
Name:	1. sag-osis I.jpg
Name:	2. sag-osis II.jpg
The frame & belly wrap seem to be trying to go in opposite directions at times. The thin belly skin gets worn out under the rivets.
Name:	3. worn through.jpg
Name:	4. worn through.jpg
Old 08-29-2010, 08:09 AM   #4
This is what I'd like to get it back to. I ended up re-riveting a couple feet along both sides and the whole rear edge.
Name:	5. desired result.jpg
Order up some wide flange rivets like these from VTS -- though there are multiple sources. Lower the tongue jack and let's get to work. A sharp 3/16th's twist drill at low speed makes new holes alongside the old ones. Get out the rivet puller and nice results happen in hardly more than 10 minutes.
The end result:
Name:	6. belly done I.jpg
Name:	7. belly done II.jpg
Of course you've got to anticipate that some of the rivets end up in your bumper locker and other places.
Name:	8. trunk locker.jpg
Old 08-29-2010, 08:15 AM   #5
Somewhere there is a thread about a period of the 2005 & 2006 production where the factory was torquing the hex heads right off self tapping screws as they installed BAL stabilizers. I had a handful that were messed up and repaired under warranty.
Inspect all five of these on each stabilizer! Here's one..
And another that will need attention again.
As nickcrowhurst always says, "The price of freedom is eternal maintenance."
Old 09-01-2010, 09:32 AM   #6
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Attachment 109582
Attachment 109583
Attachment 109584
Attachment 109585
An Airsafe hitch will help out with this problem....
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 09-01-2010, 11:14 AM   #7
maxandgeorgia's Avatar
1995 30' Limited
Ashland , Missouri
Thanks, Bob, for explanation and photos with clear cautionary advice. Drat, more to go check out! But I hate ugly surprises, so this bears a look. Thanks, again. ~G
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
1978 Argosy Minuet, 6.0~Minnie/GPZWGN
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 09-01-2010, 04:17 PM   #8
newsgauger's Avatar
1976 Argosy 28
Milton , Ontario
Airsafe Hitch...
Hello Larry C,
I’m new to the A/S forum and currently do not have an Airstream, but interested in gathering as much information as possible.
Reading through this thread and seeing your post regarding Airsafe Hitches, I was wondering if you have one and what hitch configuration (i.e. Weight Distribution, HaHa or P3) you are running.
If ‘yes’, I would appreciate hearing more from you about the combination you have.
Thanks for bringing this forward, as it sounds interesting and solves a known problem that I didn’t think about in the past.
Chris
newsgauger is offline   Reply With Quote
Old 09-02-2010, 07:38 AM   #9
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Originally Posted by newsgauger View Post
Hello Larry C,
Chris
Hey Chris,
Yes, I own an AirSafe, I bought it this spring just before a 14,000 mile trip to Alaska. I joined mine with my old style Reese Dual Cam, and it works great!
Regarding the &quot;ProPride&quot; and the &quot;HaHa&quot;, in my humble opinion, they are both extremely overpriced, and over rated. That's my opinion and I'm sure that others will disagree.
You might check out a couple of the other links, under Towing and Hitches, as we had quite a discussion earlier this year about the
AirSafe.
My experience is limited on towing, (I've only towed RV's for 30++ years), so please keep that in mind when you are reading the other links.
If you want to call, please send a private message, and I'll give you the number....
Larry
belly pan
front end bottoms out!!? Curtis-79MH Airstream Motorhome Forums 18 09-15-2003 10:13 PM
