Old 02-03-2013, 03:53 PM   #1
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
bottom first '66 caravel
Okay we have a 1966 caravel and its our new baby/project. starting from the ground up. behind the drain there is a dog dish looking object, what is it? 2. we have a gap but only behind the curb side wheel and ideas? thanks I am waiting for some materials to arrive before I start break down.
ID:	178079   Click image for larger version
ID:	178081   Click image for larger version
RM66caravel is offline   Reply With Quote
Old 02-03-2013, 05:55 PM   #2
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The "dog dish" is a cover over the "p" trap on the shower drain. The trap on ours has a removable plug threaded into the bottom. I replaced the plastic dish, which was broken in several places, with a removable stainless steel bowl.
The angle, or lack thereof, of the axle trailing arm in the last photo indicates that you need axle replacement.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
https://www.youtube.com/watch?v=Bp3nuNtlZcA&t=331s
https://www.youtube.com/my_videos?feature=mhee
Old 02-04-2013, 05:42 PM   #3
1966 17' Caravel
Thanks I will start shopping for the new axle. Did you rivet the steal pan on?
Old 02-06-2013, 12:02 AM   #4
1966 17' Caravel
More pictures
I pulled the curb side wheel for these street side still has a brake drum and no major damage.
ID:	178382   Click image for larger version
ID:	178384   Click image for larger version
Old 02-06-2013, 12:38 AM   #5
Tool Hoarder
West , California
Looks like a fun project good luck!
marzboy is offline   Reply With Quote
Old 02-06-2013, 01:00 AM   #6
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The original was a heavy plastic square with the cover cast in the center. I cut the broken bowl from the center of the plastic square leaving a round hole the replacement bowl would just press into from the top, then riveted the assembly in place. The metal bowl just fits the hole but the rolled flange around the top of the bowl keeps it from going down through the hole.
Old 02-06-2013, 07:55 PM   #7
1966 17' Caravel
I am ready to order revits for the belly pan and they will be the large flange but can somebody tell me what length I need? Mateing the 2 sheets of aluminum I can use 1/8 by 3/16th but belly pan to frame ? Thanks in advance.
Old 02-07-2013, 02:43 PM   #8
Tool Hoarder
West , California
I think the large flang rivets from VTS are 1/4 to 1/2" grip range and worked very well for me
caravel
1966 Caravel - barebones from factory? - restoration brusby 1966-68 Caravel 55 04-12-2012 07:49 AM
what options were available in my caravel? DontBSilly General Interior Topics 3 12-02-2011 05:17 AM
Caravel :: 1967 Airstream Caravel youngestmeyn Airstream Registry Discussions 0 11-29-2011 10:31 AM
Caravel :: 1967 Airstream Caravel C Johnson Airstream Registry Discussions 0 08-19-2011 09:31 AM
