Old 12-20-2009, 11:35 AM   #1
1973 31' Sovereign
Pisgah Forest , North Carolina
Big old banana wrap holes
I'm thinking about purchasing a 75 Sovereign. The exterior is in really nice condition, with one exception. There are 3-4 good size holes/rips in the banana wrap... they vary from the size of a tennis ball to the size of a football. Otherwise tho, it's in great shape. I see info here on how to remove dents and such, but what can be done about holes?
Thanks.
deepsea is offline   Reply With Quote
Old 12-20-2009, 12:14 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Could you post a couple of pictures? Are they on the corners or sides?
Old 12-20-2009, 12:27 PM   #3
Thanks.
Banana wraps are on the 4 corners. They are easily replaced. The metal variety banana wrap is history, long ago. Plastic is now used.
If the holes are in the metal on the sides, below the rub rail, that's called "underbelly wrap".
That is also easily replaced.
Which area has the holes?
Old 12-20-2009, 05:43 PM   #4
1973 31' Sovereign
pics soon thanks so far.
banana wrap holds water - can I drill drain holes? ryan3326 Belly Pans & Banana Wraps 10 09-27-2010 05:36 PM
Banana wrap repair bimpy Belly Pans & Banana Wraps 10 01-12-2008 07:26 PM
Banana Wrap Lumatic Belly Pans & Banana Wraps 2 09-05-2005 06:55 PM
Banana Wrap Blues Bobolo Repairing/Replacing Floor &/or Frame 2 02-23-2005 02:26 PM
Banana Wrap trogers713 Belly Pans & Banana Wraps 1 10-27-2003 05:36 PM
