Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 02-23-2008, 11:36 PM   #1
monocoque
monocoque's Avatar
Profile:  1975 29' Ambassador
San Antonio , Texas
Beltline Repair? Replace? Salvage?
Here's a good size dent in the banana wrap and damage to the rub-rail in my 1975, 29 ft. Ambassador. Is is possible to repair a rub-rail with this kind of damage. The aluminum doesn't seems too brittle to bend back into shape. Are these belt-lines replaceable? Supplier?
Also the banana wrap looks to be in pretty bad shape up close. I'll try my hand at a repairing/reshaping the bubble but wonder if banana wrap replacements are available? Or do I need to locate salvage for both the banana wrap and belt-line?
monocoque is offline   Reply With Quote
Old 02-24-2008, 08:36 AM   #2
PizzaChop
PizzaChop's Avatar
Profile:  1973 31' Sovereign
Danielsville , Georgia
Images: 197
Todd,
Pick up a cheap set of autobody tools (molded plastic case with 2-3 hammers, dollies, etc.) and you'll be amazed what a little patience will produce.
Your beltline will never look as good as new, but it can be made presentable, and considering it is behind your propane tanks, no one will know anyway. (I had to rework about 8' of mine, as when I picked it up, the RV place had actually bent it and stuck it inside the water heater opening so that it wouldn't fall out. Needless to say, I was sure to express my deep gratitude for their "thoughtful consideration".)
You need to drill out all the rivets holding it in place first.
The banana wrap corner pieces can be removed, most of the dents hammered out, smooothed out with bondo, and painted. All new Airstreams come painted below the beltline anyway. You will be extremely pleased with the results.
New corner pieces might be available, but they will not be cheap, or easy to acquire.
Given the state of your project, you really should have the beltline and banana wrap off the entire trailer at this point anyway, just to facilitate inspection.
Be sure to store the beltline somewhere safe where it won't be stepped on, driven over, etc.
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 02-24-2008, 09:05 AM   #3
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Ditto the above.
You may be able to pull out most of the banana wrap dents without removal using a hot glue gun to attach some scrap wood and then pull, or by a Ding King or Pops a Dent which use the same idea.
Like a couple of Balboas we headed into the wild pavement of yonder with a monstous piece of aluminum hooked to our rear end. "The Long, Long Trailer".
Old 02-24-2008, 10:15 AM   #4
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
Here are some before and after pics of mine. I removed them started with a dolly and hammers then went to body hammers and finished them off with a roller. I don't think new are available anymore in aluminum.
ID:	55003   Click image for larger version
ID:	55005   Click image for larger version
Old 02-24-2008, 10:58 AM   #5
PizzaChop
PizzaChop's Avatar
Images: 197
Aerowood,
Okay, fess up....where'd you get that roller? (I need one of those!)
Okay, not exactly behind the tanks, after closer observation....
...but my advice still stands!
Ron Kaes
Psalm 112
www.paparonnis.com
Old 02-24-2008, 11:03 AM   #6
Coastalview
Coastalview's Avatar
Profile:  1978 29' Ambassador
Carmel , California
Nice work Areowood. I too would like to know where you got that cool roller.
Jeff
78 Airstream Ambassador 29'
97 Ford Powerstroke 4x4 Crewcab Shorty
AIR# 649
Coastalview is offline   Reply With Quote
Old 02-24-2008, 11:23 AM   #7
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Keep the banana wrap! That's actually in pretty good shape. Jim & Susan has been looking for a piece of rubrail for a while. He didn't have any luck with Colaws Salvage in Missouri. Over time we do see members post about a hardluck case being parted out.
FWIW, Beltline is the trim strip about chest high between the top and bottom halves. Rubrail is the lower trim strip at the junction of the belly & banana wrap and the trailer sides.
Old 02-24-2008, 12:50 PM   #8
Aerowood
Aerowood's Avatar
Arvada , Colorado
Originally Posted by PizzaChop
Aerowood,
I made it, part of my compensation and benefits package at work is a fully equipped machine and sheet metal shop. You can see it in use on post #47 of my thread
71 Globetrotter Full Monte
Old 02-24-2008, 01:13 PM   #9
CanoeStream
Images: 13
A good friend was a naval dental technician on tenders docked at Norfolk and then San Diego. He loved the machine shop and has a nice black powder brass cannon to show for it! For the ships to stay on the Navy rolls they had to start up and move every year or so -- said the belching black smoke was something to behold.
Old 02-24-2008, 01:15 PM   #10
cameront120
cameront120's Avatar
Profile:  1972 25' Tradewind
In the same thread photos, I see some little pins (?) holding the skin in place at the rivet holes. Can you tell me a bit about these and where they can be purchased?
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 02-24-2008, 01:52 PM   #11
CanoeStream
Images: 13
cleco or clecos
Cameron, you'll get many hits if you search on either of those. They certainly can be useful for taut panel installation. aircraft-tool.com is a good source. I didn't find clecos necessary for working with banana wrap, beltline or belly skin areas.
Old 02-24-2008, 01:53 PM   #12
Lumatic
Lumatic's Avatar
1962 28' Ambassador
Clecos anyone?
I don't see the "pins" but I assume you may be talking about Clecos. Very handy spring loaded temporary fastners. They come in 1/8 and 5/32 sizes, the same as rivets. They are cheap. You will need a Cleco tool, also cheap. Got mine in a place called the Yard Store which specializes in aircraft tools.
Old 02-24-2008, 02:09 PM   #13
cameront120
Thank you Bob and Lumatic, I had seen them in passing quite some time ago and am glad to now know what they are called!
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
Old 02-24-2008, 06:50 PM   #14
monocoque
monocoque's Avatar
San Antonio , Texas
Thanks for the advise everyone about autobody tools. I'll look for a cheap set and see what happens.
BTW the banana wraps are off all the way around now for frame inspection. Not a pretty sight. See more, if interested, in the frame rot thread: Frame Rot
Toilet: Repair or Replace bilby05 Sinks, Showers & Toilets 16 01-19-2008 03:35 PM
Coleman AC repair or replace LI Pets Furnaces, Heaters, Fireplaces & Air Conditioning 4 09-26-2006 01:47 PM
Skin Repair or Replace? MarkExc500 1978- 1979 Excella 500 1 04-04-2006 02:12 AM
repair or replace a/c? hively Furnaces, Heaters, Fireplaces & Air Conditioning 12 07-20-2004 12:37 AM
Sink...Repair or Replace?? COArgosy78 Sinks, Showers & Toilets 17 08-05-2003 04:28 PM
