Old 09-15-2004, 01:21 PM   #15
JohnG's Avatar
Chuck,
I looked at the hole in my bellypan that is seen from the bumper box inside and decided to place an separate sheet of aluminum there with a bunch of rivets. Thinking that will take care of the issue of the thing falling apart somewhere like yours did. The new bellpan won't have to extend as far either.
Just adding my 2¢ worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 09-15-2004, 01:33 PM   #16
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I'll eventually do the same. I had the same trouble described earlier in the thread, though, and when I took the pan down (partially...from the bumper to the axles) this spring to inspect the framework, I didn't put it back up w/ rivets, figuring I'd be going back in there in the not too distant future. problem is, it isn't just the holes in the pan that have elongated; the holes in the frame had, too, so the screws didnt' really hold as well as was needed. What I eventually did was buy some SS hex-head self-tapping drill-point #8 screws, and drove them through the pan and frame into their own, brand new, ROUND, perfectly sized holes. So, the pan will look like swiss cheese...but it isn't coming down until I take it down.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-15-2004, 02:27 PM   #17
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Wrong brand of duct tape
Originally Posted by markdoane
I tried duct tape, but it didn't stick to the insulation. It also tends to flap in the wind at speeds above 50mph.
Mark, should have bought the 200mph tape.
Aaron
WBCCI #XXXX AIR #2495
Old 09-15-2004, 02:32 PM   #18
Images: 59
I think you could also use 3/4" hex head, zinc plated, self tapping, drill-point siding screws. They have the rubber/steel washers already in place, and I think the zinc plating would be good for preventing corrosion.
I bought these for holding down the floor channel at the corners. I don't know if I will use these for the belly pan because they tend to stick out about 1/4"
Old 09-15-2004, 02:34 PM   #19
Images: 59
Aaron
I wanted to, but they didn't have it in the 24" wide rolls.
http://www.duckproducts.com/products...bid=1&plid=569
Old 09-15-2004, 02:58 PM   #20
The Sh*tt*r's Full!
dbtolman's Avatar
1970 27' Overlander
lewisville , Texas
Originally Posted by Rae
Do you want a perminent repair ? then do as I wrote. Duct tape is for Idiots. Would you repair a flat tire with it ?
Screw are difficult and much work to apply. Firstly YOU MUST APPLY THE WASHERS WITH THE RUBBER AND POP RIVETS.
It takes 1 10th the time and holds better.
You don't need any other advice. But do as you like. you will learn.
Take it form one who has worked on Trailers for 29 years.
Rae
Sheesh! The Duct tape was a joke! The question about screws was serious, and I don't think either post warrants such an attitude. What did I do to YOU?
Obviously, I eventually plan to rivit, but self tapping screws are pretty quick if installed with a high speed screw gun, and I may want to take the pan down a few times before I finish this whole thing. I'm not trying to assert that I know more than anyone, since I know less than most about this... THAT is why I asked?!
Anyways... Thanks for what you did tell...
dbtolman is offline   Reply With Quote
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Rivet Removal pap Ribs, Skins & Rivets 11 02-06-2004 10:04 PM
Rivet holes and Door Latches JimC Doors & Locks 1 10-17-2003 10:12 AM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
Bellypan Rivet Question Creampuff Our Community 7 01-22-2003 06:42 PM
