Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 07-07-2009, 07:42 AM   #1
Profile:  1986 34' Limited
Delano , Minnesota
Bellypan Replacement Project
Well, I cleaned and sealed the exposed frame members, installed the foam board insulation, and riveted the new aluminum in place. Thanks for the advice from forum mambers. I've only done the rear, behind the tanks section, but I feel, with time and work, I can do the rest of the trailer. Here is a picture of the foam board, and a handy bellypan holder while I riveted it in place.
Name:	Foam Insulation.jpg
ID:	83551   Click image for larger version
Name:	Bellypan Holder View 3.jpg
Old 07-07-2009, 08:13 AM   #2
Roadtoaster's Avatar
Profile:  2006 28' Classic
Byhalia , Mississippi
Nice work. I especially like the pan holder using the custom sized chunk of concrete!!!! That looks like some pretty hefty pan material.
Greg
(formerly known as ptrvr)
Roadtoaster is online now   Reply With Quote
Old 07-07-2009, 10:33 AM   #3
Patriotic
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Cool! how did you secure the foam? (is that 5" of the rigid pink foam board stuff?)
when you do a new belly pan, do you use the old rivet holes, or just hold the alluminum in place, and drill all new ones?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 07-08-2009, 06:59 AM   #4
Delano , Minnesota
I used 2" foam board insulation. I cut it to fit in the frame cross member openings, which are about 57" wide and 24" long. I used a foam board construction adhesive and the caulk gun. The foam fit snugly in the openings. And I used two pieces for a total of 4". We're from Minnesota where it's always cold! The foam board did not absorb water after two days submurged in a pan of water. I think this is better than the wet fiberglass batting that was in there origionally.
The aluminum is .025 on 48" coil. I cut it to 60" long panels, and created a 60" wide by 7 foot long sheet with riveted seams every 48". I marked the center line of the sheet at 30". And I marked the center line of the frame. It is important it lines up on center before the riveting begins. Then I held it in place with the 2x4 holder and cement block risers. I drilled and riveted all afternoon! I did not attempt to use the origional holes.
I am trying to decide if I should drill some drain holes in the bellypan. The bumper wraps, sewer hose storage area and lid are not sealed, and allow rain water to run into the belly pan area. Why not let it drain out? The photos show the old bellypan corrosion, and the rear bumper area that is open to the elements.
The front of the trailer, ahead of the axles, is much longer at 24 feet. But I will use the same method. It will take me a good week of work to get it done. Maybe next year as we have traveling to do this summer.
David
ID:	83650   Click image for larger version
Name:	Clamps holding bellypan at rear.jpg
Old 07-08-2009, 07:54 AM   #5
Patriotic
Chuck's Avatar
Images: 99
interesting. I'd be concerned that any water that does manage to get between the foam and the plywood would just sit there, and rot out the floor from underneath.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 08-13-2009, 05:42 PM   #6
Profile:  1967 24' Tradewind
Redding , California
Hmm, I am thinking the same as Chuck. I'm in the midst of this and will probably put spacers o a 1/2 to 3/4" and attach the foam. This will give some airspace for drying should it get damp.
SilverHoot is offline   Reply With Quote
Bellypan re-attaching chalcedon Belly Pans & Banana Wraps 30 06-21-2009 02:48 PM
Bellypan installation Safari Tim Belly Pans & Banana Wraps 21 08-23-2007 07:58 PM
Bellypan Woes Uncle Jack Belly Pans & Banana Wraps 2 07-02-2007 04:10 PM
Scrap the bellypan? dmaiden Belly Pans & Banana Wraps 10 11-04-2006 04:29 PM
Water in Bellypan? Waterman Belly Pans & Banana Wraps 6 12-07-2003 10:41 PM
