Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Prev Previous Post   Next Post Next
Old 07-01-2009, 09:01 AM   #12
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
Originally Posted by dbj216 View Post
Taking the rear belly pan off was the easy part. Clean and seal frame members, foam insulate, and then install a new bellypan. The .025 Aluminum is on order, big head rivets on order, and I have an idea for holding the new belly pan in place while I drill and rivet.
Here are a few pictures I thought you would be interested in. You can see from the pics that my rear most frame cross member is rusted through. Standing water and wet insulation likely caused this. I figure the water gets in there through the rear sewer hose storage compartment, and the rear "bumper wraps" on each side of the trailer. There is no factory sealing system in these areas. My thinking is to provide a belly pan drain and air vent in this area so the water can get out and dry up.
Nothing like laying on the ground under an old Airstream with Minnesota mosquitoes festing on my face!
just paint it with por-15
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Bellypan re-attaching chalcedon Belly Pans & Banana Wraps 30 06-21-2009 02:48 PM
PC Experts--I need help Minnie's Mate Off Topic Forum 15 11-17-2008 02:33 PM
Bellypan installation Safari Tim Belly Pans & Banana Wraps 21 08-23-2007 07:58 PM
Scrap the bellypan? dmaiden Belly Pans & Banana Wraps 10 11-04-2006 04:29 PM
Water in Bellypan? Waterman Belly Pans & Banana Wraps 6 12-07-2003 10:41 PM
