Old 08-19-2007, 09:59 PM   #15
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
So whats the verdict?
Can we drill into the frame rails?
-Tim
theVAP - Airstream Podcast
Old 08-20-2007, 06:20 AM   #16
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Belly pan
Hi Tim,
Nice work so far. I have a 62' Safari and it had a few drill holes in the cross channels which I reused replacing rivets in critical places which really helped tighten up the metal. The cross channel is relatively thin as you know and easy to drill a few more holes and use the large belly pan rivets.
So my opinion is yes, you can drill in the cross channel.
Gary
safari62 is offline   Reply With Quote
Old 08-20-2007, 07:34 AM   #17
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
My vote is no on the Frame rails - more not necessary than anything else.
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 08-20-2007, 07:42 AM   #18
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
Yes Vote
Safari:
We are using stainless steel screws all the way, cross members and frame rails.
Phil, who has worked at a leading truck body builder for over twenty years says that, in his experience, rivets “wear through”.
That was the case with my old belly pan.
I'd use short screws and be careful about wiring.
Sergei
SmokelessJoe is offline   Reply With Quote
Old 08-20-2007, 08:10 AM   #19
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Based on my 20 years of detailing Structural & Misc Steel, I'd say you'll have no problems with drilling the few small holes you'll need to secure the belly pan to the frame.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 08-20-2007, 08:59 AM   #20
1967 28' Ambassador
1970 29' Ambassador
I concur based on what found under my 40 year old A/S.
Steve & the crew
Old 08-20-2007, 04:33 PM   #21
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Not withstanding Ken J, I'm going to go ahead and add the few rivets I need to the frame rails.
Next time, I would make the belly patches a little wider or plan around not having to do it.
Ugh... next time... I must be crazy :-)
-Tim
Old 08-23-2007, 06:58 PM   #22
1973 31' Sovereign
Portland , Oregon
Images: 22
Originally Posted by rosieriveter
Mostly it is just the middle flat piece but on the SS the next rivets up are on the side so if we end up replacing the front or back end behind the wheel the aluminum will have to be cut away or replaced in that case it have to be formed. Any Suggestions? I do have pictures but I am just learning how to navigate and I am not to savvy on to incorperate the pictures yet.
Rosie the Riveter
If the piece that you are talking about is a simple curve you will not have to do anything fancy to form it to fit. The aluminum is flexible enough to form around the curve by hand.
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
Olympic rivet removal and installation PeterH-Airstreamer Ribs, Skins & Rivets 90 11-07-2012 01:34 PM
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Installation Rally Pahaska WBCCI Rallies & Events 5 11-20-2002 09:38 AM
Broken Window Installation Charcigar Windows & Screens 2 07-30-2002 04:22 PM
