Old 01-18-2012, 03:40 PM   #1
macstrange's Avatar
1968 26' Overlander
Tucson , Arizona
Bellypan..........
trying to remove the floor and decided there is no way around dropping the belly pan. Crawled under and noticed the stabilizers are welded to the frame. looks as though they could have been bolted on after the pan, but pan is cut to allow stabilizers to contact frame for welding. Is this typical? Either way I'm going to have to cut the stabilizers away. Also, there is a steel bar stretching from one stablizer to the other and welded. Are the gas lines supposed to run under the pan or can they be run inside? I'm thinking outside is best for safety and maintainance/repair.
What are clecos?
Shawn Bradley
macstrange is offline   Reply With Quote
Old 01-18-2012, 03:51 PM   #2
1981 31' Excella II
New Market , Alabama
There is a crossmember most likely. My 81 had three bolts holding the jacks on and of course 2 of the three broke upon removal. I have never heard of them being welded but I bet that some PO tried to remove them and got frustrated and welded them back on.
Gas lines go outside so gas won't build up inside the trailer if there is a leak.
Perry
Old 01-18-2012, 03:56 PM   #3
macstrange's Avatar
1968 26' Overlander
Tucson , Arizona
After reading the '68 renovation thread, I might be heade for a shell-off.
Shawn Bradley
Old 01-18-2012, 04:02 PM   #4
1968 26' Overlander
West Richland , Washington
My stabilizers were bolted thru the pan to the frame (couple of j-bolts and large screws). Each stabilizer was bolted independently and not connected in any way to the stabilizer on the opposited side. The pan was continuous.
Clecos are used to hold pieces together prior to riveting.
Good luck!
JIMandPJ is offline   Reply With Quote
Old 01-19-2012, 06:37 AM   #5
Addicted
exthemius's Avatar
1971 27' Overlander
Currently In: Skowhegan , ME
Images: 16
Being as tall as you are, you'd need to do a shell off anyway and increase the height at least 2 feet! *joking*
-Shawn
TAC OK-42
Visit our crazy full-timing blog (us,kids and dogs living the dream): http://www.airstreamingdreaming.com/
Join us at the TAC Walt Disney World Rally, November 4th - 10th, 2012: http://www.theairstreamersclub.org/rallies/tac-fw-wdw
exthemius is offline   Reply With Quote
'53 Cruiser Where to Start? nick6930 1950 - 1958 Cruiser 74 01-14-2018 07:13 AM
'59 Pacer Shell-On Renovation worldinchaos 1959 Pacer 388 10-24-2014 11:03 AM
1966 Caravel - barebones from factory? - restoration brusby 1966-68 Caravel 55 04-12-2012 06:49 AM
Black Widow desertair27 Our Community 23 08-21-2011 06:06 PM
