Old 12-07-2015, 03:17 PM   #1
1958 18' "Footer"
1957 26' Overlander
Wentworth , South Dakota
Belly Skin replacement
So I am in the process of taking the belly skin off my 1958 18 ft Globe Trotter and have one half of it off and will use for a pattern. But when I measure the skin, its width is 51 inches. That's three inches shorter than the 48 inch thats available for sale and I don't think I will be able to overlap the two sheets on the bottom center seam. Has anyone run into this problem?
brenderay is offline   Reply With Quote
Old 12-07-2015, 11:12 PM   #2
youngpeck's Avatar
1976 25' Caravanner
Salt Lake City , Utah
Yes, I recently did the same as you. I used the old for a pattern but chose to overlap two new sheets (on each section) side to side by about a foot. It worked out fine.
youngpeck is offline   Reply With Quote
Old 12-09-2015, 03:02 PM   #3
1958 18' "Footer"
1957 26' Overlander
Figured that was the fix, thanks for the info
Old 12-09-2015, 10:24 PM   #4
youngpeck's Avatar
1976 25' Caravanner
Mine wasn't quite a "centered" overlap. My aluminum supplier suggested a slight off-center arrangement that saved me some money. I used a lot of Trempro and then large-flange 3/16" diameter blind rivets from Fastenal. Vintage Trailer Supply sells something similar. Good luck with yours!
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 09:43 PM
pipe running length of trailer outside belly skin?? Bailey56 Exterior Storage Compartments & Access Doors 2 08-07-2003 09:30 AM
Remove belly skin -- all or nothing? pilgrim_still Belly Pans & Banana Wraps 1 06-21-2003 07:50 PM
Belly skin removal Pat McSween Belly Pans & Banana Wraps 1 05-17-2003 08:23 AM
Under Belly Skin Restoration... Andy R Cleaning, Stripping & Polishing 2 04-08-2002 12:46 PM
