Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 05-16-2003, 10:17 PM   #1
Pat McSween
Pat McSween's Avatar
Profile:
Belly skin removal
HELP!
I am trying to repair a rotten section of the floor in the rear of my 1964 Bambi II. The previous owner had cut a large hole in the skin under the rear shower/lav to make repairs to the DWV plumbing. Because of this, I am going to be able to remove just the rear belly section (from the second to the last bulkhead to the rear of the unit). The problem I am having is, I have all the rivets drilled out along the bottom and the stubs punched out I can't get the belly skin to come out from under the top skin. IS the sealant strong enough to hold it in or do I need to drill out more rivets? Photos of the unit in question can be seen at http://members.cox.net/pamcsween/ .
Clear skies and smooth roads
Pat McSween is offline   Reply With Quote
Old 05-17-2003, 07:23 AM   #2
Cruiser
Cruiser's Avatar
Profile:  1952 25' Cruiser
Brattleboro , Vermont
Images: 49
belly pan removal
I recently had the same problem removing the belly pan on our '52 Cruiser. I discovered some additional rivets holding up the belly pan underneath the wall panels. I had to drill out a few of the rivets on the vertivcal seams (up from the bottom about 10") in order to gently pry the wall panels up and get to the rivets underneath. I don't know if this is the same on your (cute) Bambi, but it might be worth checking, if you haven't already.
Doug
Cruiser is offline   Reply With Quote
Skin replacement Ken J Ribs, Skins & Rivets 285 09-28-2008 03:31 PM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 06:58 AM
pipe running length of trailer outside belly skin?? Bailey56 Exterior Storage Compartments & Access Doors 2 08-07-2003 08:30 AM
Remove belly skin -- all or nothing? pilgrim_still Belly Pans & Banana Wraps 1 06-21-2003 06:50 PM
Under Belly Skin Restoration... Andy R Cleaning, Stripping & Polishing 2 04-08-2002 11:46 AM
