Old 03-25-2010, 05:27 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Belly sections
My 65 Ambassador has a belly pan that is in three sections.Two long ones and a 3x4 section that slides in the rear to cover the black tank.
I am installing a gray tank and a new black tank that will hang a little lower than stock.
Is it possible to use the existing two sections and take them to the back of the rear axle,then fabricate a new section to accomodate the tanks?
In essence I would have original belly all the way to the rear of the back axle,then riveted to a new lower piece.Does the pan need to be two continuous pieces riveted down the center all the way back?
bwaysteve is offline   Reply With Quote
Old 03-25-2010, 06:28 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Steve, Your plan sounds like a good one to me. The belly pan does not need to be two continuous pieces riveted down the center all the way back. The belly pan is not structural. Keep us posted.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-05-2010, 08:44 AM   #3
FL Crackers's Avatar
2012 27' FB International
Ft Myers , Florida
I have a related question: I've pulled what appears to be a galvanized pan from below the former bathroom of our Trade Wind. The belly skin material seems to wrap this galvanized pan on both sides all the way back to the bumper. This galvanized pan is rusted out for the most part and needs to be replaced. It was actually bolted to the underside of the frame as opposed to rivited. Could this have been an adaptation of a skin replacement? The reason I ask is that I find no mention of this particular part in the forums. Closest thing in appearance I find is a "roll out tray" at Out-of-Doors Mart - Roll Out Tray 452974 [452974] - $340.00 : ODMRV , Out-of-Doors Mart.
Mike & Laurel
Ft. Myers, FL
2012 27FB Int'l Serenity
2016 RAM 2500
FL Crackers is offline   Reply With Quote
Old 04-05-2010, 09:35 AM   #4
Ottawa , ON
Could it be the support for your black or gray tank? In mine, they sit in a pan that hinges to allow revmoval.
Old 04-05-2010, 10:12 AM   #5
Ft Myers , Florida
Originally Posted by Aage View Post
Could it be the support for your black or gray tank? In mine, they sit in a pan that hinges to allow removal.
That certainly seems to be the purpose. Wondering where I might find a replacement or if I need to have a new one fabricated. Have you heard of anyone replacing this pan?
Mike & Laurel
Ft. Myers, FL
2016 RAM 2500
Old 04-05-2010, 11:18 AM   #6
Ottawa , ON
I had a welder/fabricator make new ones for mine last summer. He did a great job.
Here's a shot from the Service Manual for the '77 rear bath model. It really doesn't show the frame, I'll have a look later at my service manual for the '74 model and see if it does.
Old 04-05-2010, 01:21 PM   #7
VIKING's Avatar
Boulder Creek , California
Mine was replaced with aluminum diamond-plate. Any good sheetmetal shop should be able to make one for you.
Best to you,
Rich the Viking
VIKING is offline   Reply With Quote
Old 04-05-2010, 01:55 PM   #8
Ft Myers , Florida
Thanks guys. this has been very helpful.
Mike & Laurel
Ft. Myers, FL
2016 RAM 2500
Old 04-05-2010, 09:22 PM   #9
Ottawa , ON
OK, here is the removal and replacement text and drawing from the 1974 book, which clealry shows both the pans and the rails that hold them in.
What about this belly? connorsa Full-Timing 12 07-13-2009 05:22 PM
Belly Skins? Dano57 Belly Pans & Banana Wraps 11 09-24-2006 09:41 PM
65 Caravel belly robandzoe Belly Pans & Banana Wraps 1 05-19-2004 12:28 AM
Obvious Holes in Forum (Model & Year Sections) Sue&Von Forum Admin, News and Member Account Info 33 04-04-2004 09:57 AM
