Old 09-06-2016, 05:21 PM   #1
Oxford , Michigan
Belly removal on '74 Overlander
Hello, one piece of the aluminum sheet is between the axel brackets and the frame I guess. I am trying to pull it out but it does not move. Does anybody know if I have to remove the axels to get this sheet out?
Udodeschl is offline   Reply With Quote
Old 09-06-2016, 07:34 PM   #2
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
It shouldn't be necessary, but it's tough with the axles in there. I tore mine into several pieces to remove it. I was planning on replacing it anyway. The axle brackets get pretty darn close but didn't actually pinch it on mine. YMMV.
TheGreatleys is online now   Reply With Quote
Old 09-06-2016, 07:44 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Welcome from Colorado. Just judging from your questions, I'll bet you in the midst of a big project renewing your Overlander.
Yes, the belly pan aluminum is installed before the axles at the factory. The aluminum belly pan is sandwiched between the frame rail and the axle bracket. The weight of the trailer is on these axle brackets.
I installed a new belly pan on my son's 69 Globetrotter and did not drop the axle. I cut the belly pan aluminum about 4" in front of the axle and about the same 4" behind the axle. I placed the new aluminum under the axle but over the old aluminum. Then I riveted the new aluminum to the old piece.
I replaced the belly pan aluminum on his trailer as the rivets corroded through the aluminum and the belly pan literally fell off. The purpose of the belly pan is to keep the insulation in place, and protect the water tanks and plumbing from splash water while towing. The belly pan is not a structural part of the trailer.
Hope this answers your question okay.
David
Name:	1604 Belly Pan 2.jpg
Old 09-06-2016, 07:48 PM   #4
1979 23' Safari
Wayland , New York
You don't have to remove the axles, but it is not easy to get it out because it has to slide almost perfectly straight to get it out otherwise it twists and binds on the sides. Look for blavk sealant along the outer edges, this can hold it in as well, need to scrape it out to loosen it. Some Chanel locks can help grip it to pull it out.
Old 09-06-2016, 07:51 PM   #5
1973 23' Safari
1970 27' Overlander
Boerne , Texas
I had this problem and got help here. All you need to do is loosen all the axle bolts then jack up the trailer just so the wheels are off the ground just a little. This will allow the axles to drop just a bit and you can pull the belly pan out easily. This worked perfect for my 73 safari
Greg1410 is offline   Reply With Quote
Old 09-07-2016, 12:55 PM   #6
1967 26' Overlander
Spartanburg , South Carolina
The original axles on my '67 Overlander had wooden shims between the Henschen axle brackets and the belly pan with the belly pan sandwiched between the frame and shims. New Dexter axles had 1" higher brackets so we let the weight rest on them, clamping the belly pan tightly. It never occurred to me to change that as I regard the clamped belly pan to be a plus. If I ever need to remove it I will just take a Dremel tool and gently trim around the axle bracket and leave the bit of sheet metal in there unless I have to remove the axles for some other reason.
Jacob D is offline   Reply With Quote
Old 09-08-2016, 05:51 AM   #7
Oxford , Michigan
Thank you very much everybody for the advice. I will cut most of it out and I will try to get it out as a small piece. If not I will drop the axel.
This project started as a just do some interior work. Then i took all the interior out, after that I found a lot of mouse crap. Now I removed the walls and the smelly insulation and I worked my way through a rust through back end. Which I get replaced tomorrow. I removed the belly. I guess I am at a point to replace everything and redo the whole trailer.
Old 09-09-2016, 02:11 PM   #8
1979 23' Safari
Wayland , New York
That's how it starts!
Old 09-09-2016, 06:42 PM   #9
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Many of us are victims of the "slippery slope", falling ever more deeply into the abyss of Airstream renovations, me included. There was a thread I followed called "replacing the shower pan, please help". Marco slipped quite a ways down the slope, but did a good job on his renovation.
I think you will find these forums very useful in your various projects on your Overlander.
Here is what I think is an mid sixties overlander. A friend sent the picture, I didn't see the trailer in person.
David
Name:	1609 Overlander Britt Casey.JPG
Old 09-12-2016, 08:44 AM   #10
1967 26' Overlander
David
My '67 Overlander has the frameless windows but the kitchen window is wider.
Old 09-13-2016, 05:48 PM   #11
1979 23' Safari
Wayland , New York
Marcos thread always gives me a good chuckle. Such a good sport!
Old 09-14-2016, 07:57 PM   #12
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I think you are right. This may be a Trade Wind, not an Overlander. There is only "2" foot difference between the two trailers. Here is a photo of my Trade Wind and it does have a small window in the galley.
David
Name:	1505 Home Street Front.jpg
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
belly pan removal problem Bradjun1 Belly Pans & Banana Wraps 13 11-03-2006 04:53 PM
Belly Pan Removal... aviontt Belly Pans & Banana Wraps 2 07-02-2004 04:47 PM
belly pan removal skip Belly Pans & Banana Wraps 6 08-17-2003 06:58 AM
Belly skin removal Pat McSween Belly Pans & Banana Wraps 1 05-17-2003 07:23 AM
