| Belly pan wraps over side, can I put it under?
Took the rear rub rail (I think that's what it is called) off today to see if saggy bottom had been repaired right, it was by PO, lucky me.
The entire belly pan is coming off for to check for repairs that may need to be done and to paint the frame.
Anyway I noticed the the belly pan, banana wrap what ever its called is over top of the sidewall instead of under it, can I and/or should I try to get it under the the sidewalls?
If I do this can I use Olympic rivets when I reinstalling the side panels to the C channel?
If I leave it as is do I just Vulkem the crap out of it before I put the rub rail back on?
No pictures today, dropped the camera and broke it.
__________________ Bruce, My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working. Parts needed: Left Wing Window Dual Pane, Fan for roof vent or whole vent fan assembly, Reese old style dual cam sway control, one 30# aluminum propane tank, vented catalytic heater
Reason: Add info
