Old 08-08-2016, 10:14 PM   #29
KYAirstream's Avatar
Northeastern , Kentucky
For those that added ventilation in the belly pan, did you do the same for the grey and black tanks as well, or did you leave them sealed to help with winter heating?
KYAirstream is offline   Reply With Quote
Old 08-09-2016, 04:48 AM   #30
toastie's Avatar
1955 22' Safari
Great Lake State , .
I used stainless steel 4" louvered vents, take screen material and cut a 4" dia. then rivet both to belly pan.
http://www.greenboatstuff.com/seadogststlo1.html
toastie
toastie is offline   Reply With Quote
Old 08-09-2016, 08:03 AM   #31
Those look nice. So you used them on the black and grey as well? No concern about contributing to tank freezing in cold temps?
I may have to try them for the interior furnace vents as well. I've never been a fan of those plastic ones.
Old 08-16-2016, 06:46 AM   #32
mefly2's Avatar
2015 25' FB Eddie Bauer
I will maintain the temperature "integrity" of all tanks; it gets too cold ...freezing...while we are still streaming into November.
Old 08-16-2016, 06:56 AM   #33
dznf0g's Avatar
Oswego , Illinois
No vents on the tank pans for me. If it gets cold, I'll just stuff some material into the clamshells.
-Rich-
Old 08-16-2016, 07:40 AM   #34
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Originally Posted by dznf0g View Post
As I said, they are screened. No rodents in 10 years. I rodent proofed the entire trailer.
3 cheers for rodent proofing! The only rodents that will be in my trailer will be the ones I invite in through the front door. 😉
Dingo Girl is offline   Reply With Quote
Old 08-16-2016, 07:48 AM   #35
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I will be using aluminum louvers, 8 x 8 inches, 4 in all front to back with aluminum screen behind them. Then hinged to be able to open them and look for problems with a camera.
In theory, it should work like a charm.
Old 08-28-2016, 07:59 AM   #36
1995 30' Excella
Lakeway , Texas
Hi,
Just some clarification if I may..."Bolt on' or screwed on your belly skins? (I can't understand a bolt being accessable)
thanks
jbs411 is offline   Reply With Quote
Old 08-28-2016, 11:52 AM   #37
dznf0g's Avatar
Oswego , Illinois
I used stainless sheet metal screws
-Rich-
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 09:43 PM
Should I Drill Weep Holes? ROADSTR6 Windows & Screens 8 07-01-2013 03:27 PM
Water tank-weep holes-mystery leak(s). Gator113 Fresh Water Systems 9 09-21-2011 03:39 PM
Should my windows have weep holes loving-life Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 09-21-2009 06:20 PM
Weep/drain holes in tank pan? rcloeffler Waste Systems, Tanks & Totes 0 05-24-2006 02:05 AM
