Old 09-16-2015, 08:22 PM   #15
1972 23' Safari
Burlington , Kentucky
I placed the jacks just under the rear bolts of each axle. That bolt hole doesn't allow the axle to pivot. The front bolt hole was elongated and allows the axle to drop just enough to "un pinch" the belly pan.
Debnw is offline   Reply With Quote
Old 10-15-2015, 11:56 AM   #16
1972 27' Overlander
Plant City , Florida
As others have said...I was all jammed up as I had to tug and pull and did not pull it out straight.....after reading this post, I went out and squirted some Nut Blaster (PB Blaster I think?) around the gap where the belly pan fits between the frame and the axels....5 min later I pulled it all the way out with one hand.
mgehloff is offline   Reply With Quote
Belly Pan, No Belly Pan DryFly General Repair Forum 32 11-18-2017 08:43 PM
Removing Belly Pan garp Belly Pans & Banana Wraps 5 07-06-2016 12:48 PM
Trying to get belly pan off stuck... Help Dustycowgirl Belly Pans & Banana Wraps 19 07-16-2014 10:02 AM
'84 Excella axle/water tank belly pan rust jman84 Belly Pans & Banana Wraps 2 07-16-2009 09:32 AM
Need HELP! Need help quick - dropping the belly pan escapeez Belly Pans & Banana Wraps 8 12-30-2002 06:03 PM
