Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Belly Pans & Banana Wraps
Old 06-08-2008, 09:54 PM   #15
musketeer
musketeer's Avatar
Profile:  1989 25' Excella
Kimball , Minnesota
Thumbs up Belly droop fixed (on my trailer)
I completed the same belly pan fix as Beginner. I used 4" wide strips of .032. I loosened the skins first and applied Por 15 to the frame, but really didn't find much corrosion. Riveted on the strips. I did use vulkem to seal them as I want to keep road sray away from the frame and I have a few weep holes which will let any moisture inside out. Thanks, Beginner!
musketeer is offline   Reply With Quote
Belly pan / Side skin seam? Ifihadtime Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 04-29-2007 06:02 PM
belly pan ....needed....or not????? leefields Repairing/Replacing Floor &/or Frame 10 01-09-2006 01:15 PM
Removing the belly pan Flyboy Belly Pans & Banana Wraps 9 11-15-2005 09:11 PM
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 16 07-18-2004 09:16 PM
Belly Pan Gaps? ajjohnsons 2003 Safari 6 07-22-2003 08:16 PM
