Old 09-03-2016, 07:18 PM   #15
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
It's "TLAR", or "That Looks About Right".
Old 09-03-2016, 09:26 PM   #16
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Originally Posted by OnTheFlyRoad View Post
Dang! I hope nobody crawls under my trailer and measures the distance between belly rivets! I've seen my share of factory belly pans, and I am pretty sure none were a measured distance apart. I'll be odd, and say mine are 9" ...
I like that....mine aren't measured either. I just put them where it didn't look like things were sagging. Very scientific...
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 09-03-2016, 09:42 PM   #17
2007 22' International CCD
Also remember, "Better is the enemy of 'good enough'"
KE4GNK/AE
Old 09-04-2016, 10:03 AM   #18
Aerowood's Avatar
Arvada , Colorado
I used all the original holes and then added a few more. I did not use pop rivets, I hate them. Instead I installed nutplates at every location and used 10/32 pan head screws. Makes removal of the belly pan very simple.
Old 09-04-2016, 10:26 AM   #19
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
got a link for those nut plates?
If you're using new belly pan material, how do you locate the holes?
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 09-06-2016, 11:38 AM   #20
Aerowood's Avatar
Arvada , Colorado
I used MS21059-3 nutplates installed with CCR264SS-3-4 nutplate rivets. I order to locate the holes I some 1/32 bolts and drilled a #39 hole in the middle of the head. I then pressed in the shank of a #40 drill bit. I then cut it off a 1/8" proud of the head and sharped to a point. Install the bolts with the new center punches. All you have to do then is get the sheet up in place where you want it and tap the sheet and it will center punch the sheet. Drill and install.
File Type: pdf Aircraft Tool Supply _ PLATE NUT DRILL JIG, #10 DOUBLE-WING STANDARD (DWS) _ 518C.pdf (36.3 KB, 13 views)
Old 09-06-2016, 03:01 PM   #21
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
neat; but it looks rather labor intensive. What do you think of using a small rivnut? Or self-tapping sheet metal screws, for that matter? not strong enough?
Air:291
Wbcci: 3752
'73 Safari 23'
Old 09-06-2016, 04:45 PM   #22
Aerowood's Avatar
Arvada , Colorado
I personally do not like rivnuts or sheet metal screws, but many have used both. I do like these however
I was afraid of the belly pan Dingo Girl 1966-68 Caravel 26 10-05-2016 03:27 PM
Belly Pan re-rivet. argosyman Belly Pans & Banana Wraps 11 04-15-2012 12:47 PM
1985 31' Excella Belly Pan Questions Eugiepayset Belly Pans & Banana Wraps 3 06-27-2011 12:04 PM
Bumper, Belly Pan and Banana Wrap Repair DKAir Exterior Restoration Forum 0 06-15-2011 05:51 PM
which aluminum sheet for belly pan???? clipperguy Belly Pans & Banana Wraps 2 04-26-2011 05:21 PM
